Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
R.I.P.
drmatera's Avatar
I'm not sure how that improves spool up but there is a company making a divided inlet flange that blocks off one side for quick spool then opens to allow top end power
Quick Spool Valve- The ultimate TQ producing part for your Turbocharged car
you have to get creative with your headers and have a divided housing. I know some guys using this on V8 engines with very large turbos and it works
Old 11-23-2011, 11:26 AM
Chain fence eating turbo
I had a thread on those:
Have any of you heard about 'quick spool valves'?
CR
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR P & C's, soon to be 993SS cams and GSXR 750 ITB's fed by 964 intake, Borg-Warner S366 turbo @ 1.4 bar, Treadstone full bay IC, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MegaSquirt 2 (v3.57 board) w/EDIS, Tramont wheels (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 11-23-2011, 11:40 AM
matsuzaka's Avatar
That is interesting, it's sort of a half way solution to a variable vane turbo. I suppose you can use a turbo on the larger end of the scale and yet have decent bottom end.
86 911 Turbo - K27-7006, BB 3" Dual outlet, BB IC
81 911SC
88 M3
11 IS250C
88 Targa - sold
Old 11-23-2011, 01:04 PM
Yep
Old 11-23-2011, 06:21 PM
wwest's Avatar
Originally Posted by matsuzaka View Post
I am a big fan of turbocharging and I think it will be a big part of automobile's future. I'm not sure if anyone has seen the technology that's highlighted in the following:
EFI University Electronic Fuel Injection Tuning :: View topic - Pre Turbo throttle?
This was technology developed in the old 1.5L turbo F1 era, it continues to be used by all World Championship Rally cars today. To understand this technology, think about what happens when you put your hand over a vacuum cleaner hose, what do you hear?
I thought you guys would get a kick out of this.
Mac
"..a big part of (the) automobile's future..."
No, what we will see in the (near) future is a multi-mode engine. Otto mode for low cylinder fill idle or cruising, Atkinson mode (70% cylinder fill) for "WOT" (50% gas pedal travel), Miller cycle, linear rise in boost, beyond 50% gas pedal travel.
Variable intake valve timing along with positive displacement, variable boost, SC. Dual drive source for the SC via a Prius-like CVT/PSD, engine and electrics, no throttle plate.
Apologies for co-oping Ford's "TwinForce" (EcoBoost) DBW throttle control technique, and Toyota's E-VVT-i extended intake timing technique.
Turbocharging is not viable with the high power stroke efficiency of an Atkinson cycle engine wherein most/more of the energy of combustion is "exhausted" via pushing the piston downward.
Old 11-24-2011, 08:07 AM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
