LinkBack Thread Tools Rating: Thread Rating: 4 votes, 3.25 average.
Tomy's Avatar
OK. Brian idea is to have coil overs as anti squat device- good.
TET930 996 TT 2003 X50 996 GT3 2004
930 1988 black on black -fast...
944 TURBO S 1989 WHITE/BLACK # 1 944 TURBO S 1989 #2
911 S 1970 Targa /ex porsche werks car!
911 S 1969 Targa (under rebuild)
Old 12-17-2011, 09:55 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #121 (permalink)
The combination used for the rear coilover set up is Bilstein Sport Rear
shocks with Rebal Racing 200# coil overs. ( No additional gusseting or
reinforcement of the rear shock towers is required)
Cole
Cole - 80 930 "The Old Sled"
Mods: TurboKraft Custom IC, 934 Headers, GSX 61, Zork, Port Work, SC Cams, Air Mod Fuel Dist Relocated, Water Meth Injection, BL WUR, MSD 6530, Greddy EBC, Synapse Bov, Short 2nd & 3rd with 8:37 R&P, Wevo Shifter, Coupling, and Mounts, MTX-L SSI-4, Big Brakes, Rebel Coilovers, Bilstein Sports.
Old 12-17-2011, 10:35 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #122 (permalink)
I've gone native
Tt surgeon's Avatar
Where can one purchase that total package?
Old 12-17-2011, 10:41 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #123 (permalink)
Tomy's Avatar
IMO you can look at rebelracingproducts.com
Old 12-17-2011, 11:04 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #124 (permalink)
I've gone native
Tt surgeon's Avatar
Cole
Cole, if one were to add these to the rear, what would you compliment the front with, the sport insert?
tia
c
'07 997.1tt
Blk/blk 600hp, bad to the bone
Old 12-19-2011, 07:07 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #125 (permalink)
Crotchety Old Bastard
RarlyL8's Avatar
Very productive day.
I drove the slant over to my friend's German auto restoration shop so we could really tear into it and see what we have. The only surprises were very pleasant ones:
> The hood latch did not work (wouldn't close) fixed that.
> Hood shocks shot, replaced.
> Squeaky wheels persist, found another broken e-brake spring, safety wired for now.
> Replaced badly cracked oil tank to engine cooler S hose.
> Changed some really nasty looking oil.
> Pulled the valve covers - no broken studs and valves in good adjustment! WoW!
> Checked plugs, they need to be replaced.
> Axle boot ripped, need to replace.
> Brake fluid nasty, need to replace.
> Found source of pretty bad oil leak, need to replace a hose.
Good day! I drove the car home with confidence as it really runs and drives well! I think if I can find one more good day over Christmas to work on 'er she'll be ready to start driving. I ordered tires for the big Fuchs so that will be nice. The cosmetics I can fix while driving/enjoying the car. This will make selling my beloved Red Rocket a little easier.
Here she is on the lift in good company!
Old 12-19-2011, 03:15 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #126 (permalink)
Registered Driver
Helmsy's Avatar
Those 356'ers are puuurdy
Ben
'85 930 - Black on Black
'95 993 Turbo - Silver
Old 12-19-2011, 03:24 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #127 (permalink)
RarlyL8's Avatar
Did you notice the RS clone in the back? That one has a fresh 3.2L to go with the light weight chassis.
Old 12-19-2011, 07:22 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #128 (permalink)
Tt:
When I started the suspension refresh I called Clint at Rebel Racing. I told
Clint that I street drive the car and was interested in some helper coilovers
that would help eliminate the squat as well as making rear ride heigth easier
to adjust. Clint suggested a combination of 200# coilovers and Bilstein
Sport shocks in the rear and Bilstein Heavy Duty shocks up front and
increasing the front swaybar size to 22mm. That's the combination I'm
running.
Cole
Old 12-19-2011, 08:28 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #129 (permalink)
totle's Avatar
Cole, what TB size are you having on the rear?
I have same setup with coilovers as helper spring on rear. 23/29 TB but way to understeer, so planning to go 22/31
Trond R.
1979 930: Garret GT35r turbo, EFI, carerra intake, Link EMS, custom GT2 cams, 98mm JE P/C, 964 crank (stroker), custom valves & ported (XtremeCylinderHeads) etc..etc..
1972 914-6 GT replica project
1986 944 Turbo
Old 12-19-2011, 11:31 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #130 (permalink)
Smart quod bastardus
fredmeister's Avatar
I may jump in and beat Cole to the punch....I am running 22frt -31 rear, hollow t-bars on my 79 930 with no helper springs. Car weighs 3190 lbs with me in it. So its not a stripped out shell, and these t-bar sizes work out pretty nicely. I drive it 50% street and DE, and the ride is not overly stiff on the road. It squats very little under acceleration as far as I can tell. I need to have someone follow behind me on track to let meknow how bad it is though.
The car is fairly neutral, though it still understeers slightly when tracking it thru low speed turns on DE days. Nothing that cannot be modulated with a little throttle steering with good use of the gas pedal. You can also trim it with adjustable sway bars to dial it in.
Fred
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, B&B intercooler, Snow Perf water/meth injection, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.7bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 12-20-2011, 08:05 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #131 (permalink)
Ken911's Avatar
mine is squatting pretty bad now also. Since i finally got the wur dialed in correctly with the higher displacement/ compression ratio and boost. when i nail from off the line to at least 3rd gear it feels like the front wheels arent on the ground.
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's.
05 Cayenne S lapis blue
Old 12-20-2011, 08:10 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #132 (permalink)
DSPTurtle's Avatar
So what's wrong with that? Less friction on the road surface to slow you down
JB - BreitWerks
www.breitwerks.com
321-806-8664
Engine Rebuild & Restorations
Old 12-20-2011, 08:28 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #133 (permalink)
EA930's Avatar
I have the same problem- I think I need to stiff the rears and lower the front a bit... Looking to add coil overs if I can get a hold of Clint at rebel racing. Called and no answer, sent an email and nothing yet...
Old 12-20-2011, 05:14 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #134 (permalink)
Ken911's Avatar
unless it decides to change lanes on you lol
Old 12-20-2011, 07:06 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #135 (permalink)
Non User
infraredcalvin's Avatar
Word on light steering, one caveat, I was running stock boost with a stock build, but at wot the front felt like it was about to leave the ground. It was my alignment, had it looked at and adjusted, it solved the issue (didnt think to ask what they changed). I know you guys are running much more power, but something else to think about...
Brian, when are you going to change your sig line, you've got a big boy car now
Infraredcalvin - AKA Pat
'76 Turbo Carrera #311 - Factory LSD, Sport Seats
'75 914 GT clone project
'71 914 track car
Old 12-20-2011, 09:15 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #136 (permalink)
RarlyL8's Avatar
Big boy car, he he. The gray car sits in the corner with her mouth shut next to the red rocket.
After the '78 sells I'll start enhancing the '85. She'll be the new test bed and will go through a quick evolution. I plan to start with a variety of turbos on the stock engine then go to my headers and repeat with larger turbos. I've got a prototype muffler in the works that needs more road time as well. We will test the limits of CIS on a stock engine with stock redline. I really want to see how far you can go with a bone stock engine with only bolt-on exhaust parts and modified CIS.
Old 12-21-2011, 04:59 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #137 (permalink)
jsveb's Avatar
Brian, I am very much looking forward to all your testing.
As a break in the show can you tell a little about what turbos you'll be testing?
Old 12-21-2011, 06:07 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #138 (permalink)
Bri:
Really great to hear your settling in with the Slant. Enjoy, It's one of the
most iconic cars ever built. Have fun !!!!!
Cole
Old 12-21-2011, 06:18 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #139 (permalink)
Non User
I should talk, theres always a certain amount of sentiment towards the current mistress, I feel guilty spending more time on the 930 while neglecting the 914 (how lame is that?).
Your grey car is a monster waiting to be unleashed! I look forward to the updates and testing as I'm on a similar path, but with the smaller 3.0....
'71 914 track car
Old 12-21-2011, 07:05 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #140 (permalink)
