mark houghton's Avatar
windshield fit years?
OK, call me lazy but I thought I would ask the brain trust for a quick answer before trying to research elsewhere.
I ran across a potential good deal on a used windshield, since mine sucked up a large asteroid this summer. I'll eventually replace it with new, but having a spare (though used) one on had at a good price is worth it.
But, it's from a 1981 930 Coupe, whereas mine is an '87. I presume the body geometry didn't change between those years but don't really know for sure. Are '81 and'87 interchangeable?
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, stock everything else. The result of a massive Pelicanite good will fire recovery effort. Truely an open book, ready for the slippery slopes to modification.
Old 11-30-2011, 07:06 PM
Hey Mark, yes the they are the same glass with the antenna in the windshield , the 89 and up will fit also but with the smaller seal because the glass is larger from 89 to 94,and 95 thu 98 will also fit but with the glue in seal and that glass is even larger, have a great Holiday.
Helio
1986 944 turbo -first car
1997 993 Cab 6 speed-sold
1992 964 C2 turbo
SOLD, 911GT ,CIS, 428 fwhp 450 trq, Carrillo rods, 964 cams, TT retainers,7.5 comp 1.1 bar boost 320 ml black fuel head 009 injectors, 044 pumps, 60-1 T4/T3 dual scroll turbo
Old 12-01-2011, 08:08 AM
rsrfan's Avatar
Mark when I undertook the 934ish conversion i went with an early non-antenna windshield as I run no stereo and brand new it was only a couple hundred dollars....
JP
86 930/4 tribute beasty
81 sc beach beater
55 Belair
40 Ford pickup
Old 12-01-2011, 08:44 AM
IMR-Merlin's Avatar
"95 thu 98 will also fit but with the glue in seal and that glass is even larger"
So if I am building an 82 930 and want an updated style seal and windshield that is glued in, I can order this windshield and have it installed by my glass guy? I have been looking for a way to replace the older style rubber seal.
Old 12-01-2011, 10:15 AM
kinein's Avatar
Send a message via Yahoo to kinein
i have a 86 911 and i just recently put a 964 glass in from a 93 but you have to use the right rubber for it
Old 12-01-2011, 10:37 AM
Metal Guru
911nut's Avatar
What I've been told, the 964 glass and seal have sealer applied between the gasket and body.
The 993 glass uses an inner and outer gasket and gets bonded in.
Neither gasket use the aluminum trim of the prior model.
Paul B.
'91 964 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, - 210 lb
Old 12-01-2011, 01:44 PM
