Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
Brando
quattrorunner's Avatar
Whated I do?
So my swap to 930 has been slower than others on this board, it's embarrassing but with 7 kids and a business to run.......
So I wanted to turn the engine over since I finally got my scavenge system complete and filled it with oil. I get nothing from the starter. My 77 wire harness is very similar to the 77 930 harness. Same yellow, and red. Only difference is the CDI/ permatune but I'm going msd(not wired yet) . My starter appears to be hooked up right, only real change has been to an external voltage regulator alternator. I rebuilt the engine and it turned over before I installed it. Any ideas why my car won't turn over? Btw I have 12.35volts. Thanks.
Old 11-30-2011, 11:02 PM
Have you checked the ground connections?
Old 12-01-2011, 03:01 AM
Brando
Let's see, there's the one at the transmission, the one on the alternator to the case, the ground wires in the harness, the strap at the battery.....is the another? I'm sure I wired the starter up, and there is a ground there too right?
Old 12-01-2011, 06:07 AM
PrimeMvr's Avatar
This is not based in factual review of wiring diagrams, so it could be a coincidence. I had the same issue last spring. I ran a jumper cable directly to the solenoid and confirmed that the starter was ok, powered and grounded.
I proceeded to unplug and plug every connector in the engine bay. I think what fixed it was the 14-pin connector on the driver's side. Again, this was total trial and error and I don't know for sure if the 14-pin has anything to do with the solenoid circuit.
I would start by running a jumper to the solenoid post, get out from underneath (!) and touch it to the battery post and see if it turns over. That will rule out power, ground and functional starter.
87 930 - Black - 3.4L/964 cams/K29/Powerhaus IC/6AL-2/B&B dual exhaust/MTX-L/235-315 Toyo R888/18" Kinesis wheels/Big Red brakes/LSD
10 997.2 Cab - Speed Yellow
83 SC Cab - Guards Red [SOLD]
17 NSX - Nouvelle Blue
Old 12-01-2011, 06:31 AM
Brando
Cool, I'll try that tonight. Thanks
Old 12-01-2011, 07:19 AM
Brando
I washed the old engine and transmission at the car wash with the starter attached. Ya think I messed it up?
Turbo powa!
1977 911s. it's cool
Old 12-01-2011, 01:05 PM
Brando
Turbo powa!
Old 12-01-2011, 01:13 PM
Brando
Well I had good results I thought I would share. I jumped the starter from the batt and still nothing. So I took a closer look an found that I had a loose nut on the starter, the one that is the negative terminal, so yeah, ground and right on the starter itself. I felt stupid but happy it is sorted out. Thanks for the help.
Old 12-10-2011, 11:26 PM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
