LinkBack Thread Tools Rating: Thread Rating: 2 votes, 5.00 average.
Originally Posted by Joeride9 View Post
Another question for you guys. How are all of you suppling and returning the turbo oil? I am going to use the stock k2
And again thank you for all your replies!
Joe D
-4AN supply line from oil pressure dummy light switch on the back of the motor.
Gravity draining to the sump oil drain plug is the easiest solution.
Pelicans what waste gate and size are you using,and BOV?
Tanks Joe D
A 46mm TiAL Wastegate with a 0.5bar boost spring.
A 50mm TiAL BOV. Others have used a single billet 996TT unit with good results too.
Headers - Any 930 turbo header solution will work, or even a 930 J-pipe if you're on a tight budget.
Turbo - Depends how much power you're aiming for. From a K27-7200 through to a Garrett GT35R ball-bearing unit... GT3071R is a good match for a low boost setup. BIG power goals later, go with a GT35R.
Intercooler - Not needed for 0.5bar. When aiming for 0.7bar+, then a full bay intercooler is required.
FPR - BEGI Adjustable Boost Sensitive Fuel Pressure Regulator, or an 8:1 fixed FMU will work well too. Protomotive have one too, but expect to pay upwards of $400-500 for it! The BEGI adjustable unit offers some adjustability to fine tune your AFR's.
Injectors - The stock injectors are fine for up to 400HP.
Ignition - MSD 6ABTM boost retard ignition system set to 0.5 - 1.0 degree retard per PSI of boost.
Good luck! Post results
Old 12-07-2011, 12:14 PM
Thanks again!!!
Old 12-07-2011, 12:19 PM
Chain fence eating turbo
Previous owner of my car had stock injectors making 515chp. It had over 100PSI of fuel pressure to make that power.
Old 12-07-2011, 03:29 PM
Hi again pelicans can you all tell me what spring rate you are using on your BOVs thanks Joe d
Old 12-08-2011, 03:27 PM
