Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
Adriano's Avatar
Wheel / tire fitment question
Hi guys, have a stock '87 930 that I want to dress up cosmetically. Can some of you "in the know" tell me if this combination will fit without altering my sheet metal?
The wheels are Simmons 3pc, Front 17x9 ET 25mm; Rear 17x11 ET 38mm
Kumho Ecsta XS
Front = 245/40-17
Rear = 315/35-17
Many thanks in advance.
Adriano
87 930 coupe
97 Carrerra cab
97 993tt
Old 12-06-2011, 12:01 PM
Adriano's Avatar
btt
87 930 coupe
97 Carrerra cab
97 993tt
Old 12-08-2011, 04:26 AM
Adriano:
Off the top of my head you should be ok. If you still have the original
spacers in that would give you some adjustment to work with if it's close.
Cole
Cole - 80 930 "The Old Sled"
Mods: TurboKraft Custom IC, 934 Headers, GSX 61, Zork, Port Work, SC Cams, Air Mod Fuel Dist Relocated, Water Meth Injection, BL WUR, MSD 6530, Greddy EBC, Synapse Bov, Short 2nd & 3rd with 8:37 R&P, Wevo Shifter, Coupling, and Mounts, MTX-L SSI-4, Big Brakes, Rebel Coilovers, Bilstein Sports.
Old 12-08-2011, 01:03 PM
Those are the size...
tires I run with no problems of rubbing at all. Not sure on the back spacing though. Certainly gives the car a different feel with the big tires on the front, but still manageable. Philip
87 930 GHL/Rarlyl8 dual/Garretson/GT3582R/1 Bar/Wevo shift, mounts/Meth inj/LC-1/Custom Fuchs/Carrera intake manifold/Xtreme Carrera heads P&P/3.4/DR 993SS cams/ Mahl/Pauter/JE/Niresist/ARP/twin plug coil packs/8.25:1/KEP stage 2/twin tials/close 2,3,4th. MS3Pro Evo install in progress. 500+ HP, BTSOMP Dyno
Old 12-08-2011, 01:15 PM
Registered Driver
Helmsy's Avatar
You should be fine but as these cars were basically hand-made and getting old (with chances of dings and repairs) the guards aren't all equal.
I had that combination (those exact tires) and had to trim a tiny amount off the inside of one rear guard to eliminate rubbing.
Can you test fit the wheels before buying?
Ben
'85 930 - Black on Black
'95 993 Turbo - Silver
Old 12-08-2011, 02:15 PM
Adriano's Avatar
Yes , I can test before buying.
Thanks for the feedback guys, invaluable as always.
87 930 coupe
97 Carrerra cab
97 993tt
Old 12-09-2011, 05:41 AM
The 9 and 11 are OK. it all depends on the backspacing. Trying them on will tell you pretty darn quick.
Old 12-09-2011, 06:04 AM
Crotchety Old Bastard
RarlyL8's Avatar
9" ET25mm = ~6" backspace
11" ET 38mm =~7.5" backspace
Old 12-09-2011, 09:30 AM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
