euro injectors
I picked up these euro injectors and a set of fuel lines to install when I do my motor swap. It doesn't appear that these injectors use o rings. Can someone confirm this is correct, so I'm not looking to get o rings over Christmas. Philip
87 930 GHL/Rarlyl8/Garretson/GT3582R/1 Bar/Wevo shift, mounts/Meth inj/LM-2/Custom Fuchs/Carrera intake manifold/Xtreme Carrera heads P&P/3.4/DR 993SS cams/ Mahl/Pauter/JE/Niresist/ARP/twin COP/8.25:1/KEP stage 2/twin tials/close 2,3,4th. MS3Pro Evo 500+ HP, BTSOMP Dyno
Old 12-08-2011, 02:01 PM
Registered Driver
Helmsy's Avatar
No o-rings but you should use new crush washers - our host calls them a sealing ring.
Damn those are shiny!!
Ben
'85 930 - Black on Black
'95 993 Turbo - Silver
Old 12-08-2011, 02:09 PM
Ben
What size sealing rings would I need ? Will the size for the fuel dist. also fit the fuel filter ? thanks Philip
Old 12-08-2011, 02:18 PM
jsveb's Avatar
I simply went out to a truck shop with one of the old washers and an injector. That way we found suitable copper washers.
It works and it was cheap
Jesper
Carrera 3.0 1975
930 1978 OEM Matte Schwartz, ANDIAL IC, BL WUR, SC cams. LMA-3 w. XD-16 and CP transducer
www.stauningwhisky.dk
Old 12-08-2011, 04:08 PM
gmendo's Avatar
They are 10mm x 13mm
These work
Pelican Parts - Product Information: 900-123-033-20-M17
'80 Guards Red 930, '89 Black 928 S4, '92 SLC Corrado, '03.5 Final Ed. Lotus Esprit, '06 Murcielago
Old 12-08-2011, 05:04 PM
