Need info please on CV's
I have an 82 930 and I am installing a G50/01 from a donor car. Will my CV's work out of the 930 or should I use the axles out of the G50 car? A fellow pelicanite needs a 930 CV and if I am not using mine, he's getting it. SmileWavy
Thanks in advance, Brendon |
You can use your axle assemblies.
Thanks |
CV joints
930s through 1984 = # 930 332 034 00 : Axle Joint, Rear Inner/Outer (4 Per Car) 911 Turbo 1985-94 Inner/Outer & 911 1986-89 Rear Inner (2 Per Car) # 911 332 923 01 : Axle Joint Kit with Boot |
| All times are GMT -8. The time now is 04:05 PM. |
