Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
j911brick's Avatar
Oil line Dilema
I'm working a '82 euro 930 and I can't seem to get the correct oil lines The oil line I'm having trouble with is the return line from the engine to the thermostat. The oil return system is like SC with the hard line that goes around the back side of the motor and connects near the oil tank. But the PET says the line number is 930.107.729.10 which is the line with the hook in it like one would use on an SSI conversion. So I thought I would just order SC line which is 911.107.729.10, but sales tells me THAT is the line for the SC conversion. So now I'm confused. Does anybody know the part number for the correct oil line that goes from the hard return line to the thermostat?
TIA
james
www.gruppe9autowerks.com
Its not how fast you go...its how you go fast
Old 12-15-2011, 05:30 PM
Crotchety Old Bastard
RarlyL8's Avatar
P/N 930-107-729-10 is the soft line with the hook in it for backdated engines.
P/N 911-107-739-10 is the hard line that goes under the tranny.
Old 12-15-2011, 05:38 PM
Is this the line your looking for?
I have one I've taken off if your interested.
Cole
Cole - 80 930 "The Old Sled"
Mods: TurboKraft Custom IC, 934 Headers, GSX 61, Zork, Port Work, SC Cams, Air Mod Fuel Dist Relocated, Water Meth Injection, BL WUR, MSD 6530, Greddy EBC, Synapse Bov, Short 2nd & 3rd with 8:37 R&P, Wevo Shifter, Coupling, and Mounts, MTX-L SSI-4, Big Brakes, Rebel Coilovers, Bilstein Sports.
Old 12-15-2011, 05:53 PM
j911brick's Avatar
Cole
I need the oil line that goes from this line to the thermostat.
james
Old 12-15-2011, 06:07 PM
j911brick's Avatar
So I don't need either of these... Do you know the one I need?
james
Old 12-15-2011, 06:08 PM
James:
Sorry Bud, I don't have the one you need.
Cole
Old 12-15-2011, 06:15 PM
j911brick's Avatar
James:
Cole
No prob. I have the line. I just need the part number to order a new one.
james
Old 12-15-2011, 06:21 PM
RarlyL8's Avatar
930-107-743-10 (-M127) is the line that attaches to the hard line in Cole's picture.
Old 12-15-2011, 07:06 PM
j911brick's Avatar
Thanks. I was just doing some research and came to the same conclusion. I think the PET made the whole issue confusing.
james
Old 12-15-2011, 08:45 PM
j930's Avatar
if its the one that goes to the front of the car.... i had a new one built to replace the pieces in between the steel lines. got a nice clamp and a good hose and ZERO leaks. very cost effective. and its removable now.
84 930 Slant
15 Sonata 2.0T
08 Ram 1500
15 Ram Eco Diesel
Old 12-16-2011, 05:37 PM
j911brick's Avatar
I could have done that but the hard line is old and corroded and would not look right next to all the other new parts.
james
Old 12-17-2011, 09:30 AM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
