LinkBack | Thread Tools | Rate Thread |
Kartoffelkopf
Engine Loom - Plug p/n's?
Our host sells at least one side of them... male I think. But not sure where to get the female (thank goodness I am already married).
JB - BreitWerks www.breitwerks.com 321-806-8664 Engine Rebuild & Restorations |
I bookmarked this thread Broken 14 pin connector
I seem to remember that you can find both parts by grovelling about in PET for long enough.
'77 S with '78 930 power and a few other things. |
Check the 87-89MY PET. I think that is the first edition where these parts were clearly identified. I've recently purchased a couple of sets so I know that Porsche has them in their warehouses here in the States. I did not try to source them here on Pelican. You will get the bakelite pieces AND the pins. You'll need to solder the pins onto the wires and packing all 14 wires in the fitting is somewhat of a challenge. Good luck. If you can't find the part number in PET, drop me a note and I will dig up the part number for you.
Merry Christmas! Toby
Toby Pennycuff Dallas, TX 1979 930 Petrol Blue Monster 1968/1973 911S MFI #73 - Tweety Bird. 911 PCA Club Racer. E Prepared 2001 GT3 Cup #77 - O M G! |
I don't know about a 1992 964 turbo CIS injection lambda harness but on a 930 the lambda harness uses one of those plugs. It's mounted on the shock tower crossmember behind the motor closer to the left side upper shock mount.
On a 930 converted to EFI and crank fire ignition the CIS lambda stuff has no use and is history so all the problematic relays and the k-jetronic ECU under the driver seat is deleted and the harness that connects them to motor is not used anymore so you could use that multi pin pug for something else. All the wires in the plugs are hand soldered to the removable male and female pins so it's easy to change the wiring to them. |
Kartoffelkopf
Cheers guys, will take a look. As said, most of the stuff I need is taken care of by the EFI loom
Ta S |
Thread Tools | |
Rate This Thread | |
