993 windshield and rear glass update on 74 to 88
Has any one updated there glass and seals to 993 ?
I have updated my glass before back in the 90's to 964 glass and trimless seals, front and rear , I had already updated the side door frames and rear 1/4 windows to the 993 style, and that was very simple , I have already ordered all four inner outer seals, and the factory 993 front and rear glass, It should give me a cleaner look and less wind noise and I think greater chassis rigidity because it is bonded to the chassis , parts should be in next week ,I will post pic's of the processes, if any body is interested if you have done this before, please let me know what to expect. Thanks Helio
1986 944 turbo -first car 1997 993 Cab 6 speed-sold 1992 964 C2 turbo SOLD, 911GT ,CIS, 428 fwhp 450 trq, Carrillo rods, 964 cams, TT retainers,7.5 comp 1.1 bar boost 320 ml black fuel head 009 injectors, 044 pumps, 60-1 T4/T3 dual scroll turbo Last edited by heliolps2; 01-25-2012 at 02:12 PM.. |
interested in the outcome. I am looking to do this as well
Make sure you post pics for us that are also interested in doing this as well. Good idea.
Tony 91 964 c2 black/ Work in progress/Finally back on the road 85 EURO 930 Black slightly moded slowly reviving her 77 911tt EFI wide body red/ Slightly modified ![]() SOLD
I hope I'm wrong, but I think I read in a 993 book; the body was enlarged by a little over ther 964. I hope it has nothing to do with the window frame areas. I also have 993 and like the look of the trim/ window seals.
I'll will find out soon , I will update with pics
well got it done today very simple and straight forward , Safelite came to the house and installed it, if you have in questions I'll be glad to help.
1986 944 turbo -first car 1997 993 Cab 6 speed-sold 1992 964 C2 turbo SOLD, 911GT ,CIS, 428 fwhp 450 trq, Carrillo rods, 964 cams, TT retainers,7.5 comp 1.1 bar boost 320 ml black fuel head 009 injectors, 044 pumps, 60-1 T4/T3 dual scroll turbo |
Great NEWS!!! I have a guy that does glass!!!
What about side glass without the trim? 964 seals? |
Wow it looks alot better, the 993 front and rear glass needs the factory 993 seal (4 of them)as for the rear 1/4 glass I used 993 glass and seals , those just get roped in, unlike the the front and rear those get glued in, I also replaced the door window frame with 993 , they just slide in place and bolt on ,
Ouch, not sure if I want to order that much glass. I thought you could get rid of the metal trim and use 911 windows with different seals. Not a fan of the metal trim at all.
Def looking into the 993 front and rear glass/seals. |
It does get expensive , all the glass on my car is all Porsche OEM, the front and rear glass and seals cost just over $ 2,200.00 oouch
I am not concerned about factory glass, I can source the front glass for $220 locally.
I have gone though alot of glass over the years ,aftermarket glass seem to pit alot easier
IMR-Merlin can you share your secret place for the windshield for $220? Also what kind of glass? Thank you.
Ok thanks. I thought you had someone you deal with.
