I've gone native
Tt surgeon's Avatar
Turn signal stalk removal
Replacing the turn signal stalk, anybody know how the old one comes out? Don't wanna start breaking things.
tia
c
'07 997.1tt
Blk/blk 600hp, bad to the bone
Old 01-27-2012, 05:29 AM
From what I remember when I did it, it was pretty easy.
Remove the clam shell cover (two small screws)
Unplug the wire harness to the stalk
Remove screws that hold the stalk in place.
Jeremy C.
Why's he calling me meat? I'm the one driving a Porsche. (Bull Durham)
----Nothing is far away in this car!---
-2001 996 Turbo
Old 01-27-2012, 05:48 AM
I've gone native
Tt surgeon's Avatar
c
'07 997.1tt
Old 01-27-2012, 06:41 AM
pete3799's Avatar
You will need to remove the steering wheel to gain access to the 4 other screws holding the clam shell on.
Pete
79 911SC RoW
Old 01-27-2012, 07:10 AM
M5guy's Avatar
If you are replacing the turn signal/high beam unit with a new one, I advise unplugging the wires under the dash one at a time, and plugging in the corresponding new wire one at a time. The plugs are not all that easy to see.
Be sure to mark your steering wheels position before pulling it off so that you put it back on straight.
Old 01-27-2012, 11:48 AM
j930's Avatar
+1 on marking the wheel position. i had to redo it like 3 times to get it straight. and yeah just pull the wheel like they said above and its really obvious how to dis assemble.
84 930 Slant
15 Sonata 2.0T
08 Ram 1500
15 Ram Eco Diesel
Old 01-27-2012, 03:14 PM
I've gone native
Tt surgeon's Avatar
Thanks all, worked like s charm!
Next mission, backup light switch.
Old 01-27-2012, 06:21 PM
j930's Avatar
back up light switch is quite the pain in the but. its on the passenger side of the tranny. if you can get the car on a lift it would be much easier. on mine i could not access the switch as easy as it appears as the tranny would not allow for a open end wrench to grab it. also be sure and check/replace the small metal rod that is behind the switch as on mine it was not the correct one. i had made up one like discussed in the forums but finally went ahead and ordered the right one through porsche. it was not that much and it was the perfect length. depending on the tranny you have there are a few different length pins. make sure you get the correct one. at least that what i am told as the dealer had to re-order the part several times as they kept coming in the wrong length.
84 930 Slant
15 Sonata 2.0T
08 Ram 1500
15 Ram Eco Diesel
Old 01-28-2012, 07:53 AM
I've gone native
Tt surgeon's Avatar
Sounds like a pain, can't wait!
Old 01-28-2012, 12:05 PM
j930's Avatar
its not that bad, i probably made it sound worse than it really is.
84 930 Slant
15 Sonata 2.0T
08 Ram 1500
15 Ram Eco Diesel
Old 01-28-2012, 12:51 PM
I've gone native
Tt surgeon's Avatar
You don't remember the size wrench do you?
Old 01-28-2012, 03:00 PM
SweetWaterSurprise's Avatar
For the switch itself? I believe it's 22MM if I remember. I had to make a pin myself before and replace it.
Old 01-28-2012, 04:08 PM
22mm socket
Like previously mentioned, a wrench won't go on the switch, due to interference! Need a socket. Philip
87 930 GHL/Rarlyl8/Garretson/GT3582R/1 Bar/Wevo shift, mounts/Meth inj/LM-2/Custom Fuchs/Carrera intake manifold/Xtreme Carrera heads P&P/3.4/DR 993SS cams/ Mahl/Pauter/JE/Niresist/ARP/twin COP/8.25:1/KEP stage 2/twin tials/close 2,3,4th. MS3Pro Evo 500+ HP, BTSOMP Dyno
Old 01-28-2012, 04:59 PM
j930's Avatar
i think it must be a special notched socket as i could not get it around the switch? i am sure there is a trick to it! and 22mm sounds right
84 930 Slant
15 Sonata 2.0T
08 Ram 1500
15 Ram Eco Diesel
Old 01-28-2012, 09:35 PM
pete3799's Avatar
The wires plug into the back of the switch. Pull the wires then slide the socket on.
Pete
79 911SC RoW
Old 01-28-2012, 09:56 PM
j930's Avatar
mine must be different as the socket won't slip completely over the switch it stops just prior due to interference with the tranny.
84 930 Slant
15 Sonata 2.0T
08 Ram 1500
15 Ram Eco Diesel
Old 01-29-2012, 06:12 PM
I dropped down the tranny a bit before I worked on my switch
Old 01-29-2012, 07:14 PM
j930's Avatar
ok that makes sense. i am not that mechanically inclined.
84 930 Slant
15 Sonata 2.0T
08 Ram 1500
15 Ram Eco Diesel
Old 01-30-2012, 04:02 PM
19MM to do that part
Old 02-01-2012, 08:03 AM
