gavinc69's Avatar
930 WUR on 3.0 SC
Hi,
I'm nearly ready to start a turbo conversion on my 1980 3.0 SC engine.
After reading lots of Pelican posts fueling appears to be the most awkward issue.
I have just managed to get a used 930 WUR very very cheap and wondered if that would work in place of my 3.0 SC WUR?
I was thinking that due to me only running 0.5bar a standard 930 WUR should work OK and wouldn't need to be modified as required for the guys running 1bar on the 930 engines.
They appear to be very similar with the additional of a vacuum port on the 930 version which I think richen's the mixture when on boost.
Does anyone know if this will work?
Gavin
1980 SC Flatnose, Euro 3.0, LW Flywheel, 993 Cams, Port & Polish Heads, RS Cut Valves, Magnacor Leads, Boxster Brakes, WEVO Mounts, TRG Roll Bars, Rollcage, RSR rear fenders, WEVO Shifter, K27 7200 Turbo, OBX Headers, Tial Wastegate, Omex 710 ECU, 3.2 Intake, Full Bay Intercooler.....400HP
Old 10-16-2012, 10:56 AM
