-   -   can I use this gauge to test WUR..... (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/657705-can-i-use-gauge-test-wur.html)
ertech 02-12-2012 06:38 PM
Hi guys
can I use this gauge to test WUR, or do I need the more expensive type
Thankshttp://forums.pelicanparts.com/uploa...1329100672.gif
jsveb 02-13-2012 08:22 AM
I think you need a gauge that you can hook up in-line with the wur and the fuel head.
You also need to be able to close the valve from the gauge to be able measure system pressure.
That one look neat though. Where to buy?
mooney265 02-13-2012 05:45 PM
Unwired Tools has that...
ertech 02-13-2012 06:00 PM
That is where it is from at only 45 $. Needed to know if i could use to adjust the wur
mark houghton 02-14-2012 05:40 AM
I believe you can hook that gauge in one location or the other, to read either system or control pressure, but not both at the same time. Seems I've seen a picture or two of similar guages being installed permanently on the WUR.
billjam 02-14-2012 06:02 AM
I bought a few fittings, a valve and gauge and put this together. You need to be able to close the valve to measure system pressure. Cold control pressure is measured with valve open.
It's all in the manual, but if you want something easier to follow, I can email you my version of an idiot's guide to measuring fuel pressures and flows.
http://forums.pelicanparts.com/uploa...1329228022.jpg
