Fuel Enrichment CIS 911 & 930
I know this has been covered before and i've read through numerous threads on fuel enrichment. Most are for the 930 for obvious reason's.
The engine has just been rebuilt with some mods done and they say ideally it needs to run just a little richer, they've gone as far as they can without modifying other components like WUR. It made 232HP as is but 237HP when the WUR was bypassed/disconnected and higher fuel pressure then run. (993 CAMS, Ported & Polished Heads, RS Cut Valves, Fabspeed headers/muffler, MSD 6AL+Blaster Coil+Magnacor's+Gapped Plugs) I'm posting in the turbo section because I will be doing a turbo conversion soon and am collecting parts now (looking to run 0.5bar, intercooled). Is the SC 3.0 WUR possible to modify in the same way the 930 WUR is? and would that be the best and most reliable way to increase fuel supply? I have also read about microfuelers, which would work under boost or certain rpm's. Would a modified SC WUR be sufficient for a turbo conversion or would I be best with a microfueler aswell? I'm guessing the SC WUR hasn't got the option to enrich under boost either like I think the 930 WUR has? I was also wondering if an uprated fuel pump would help like the Bosch 044? SHINNY SHINNY ![]()
1980 SC Flatnose, Euro 3.0, LW Flywheel, 993 Cams, Port & Polish Heads, RS Cut Valves, Magnacor Leads, Boxster Brakes, WEVO Mounts, TRG Roll Bars, Rollcage, RSR rear fenders, WEVO Shifter, K27 7200 Turbo, OBX Headers, Tial Wastegate, Omex 710 ECU, 3.2 Intake, Full Bay Intercooler.....400HP |
