1986 930 intermittent dies
Friend has an 86 930 that will die while he is driving along. No rhyme or reason, and it usually starts right up after he pulls over. Sometimes he can re fire if he cycles the key. It is happening with more regularity lately, and I told him I would drive it and try to fix problem.. I have seen a # of threads regarding the two red fuel pump relays, yellow relay, throttle plate switch, overboost switch, and under seat relays.Also alarm module, fuses.
etc,.. How can I obtain a wiring diagram to follow the electronic path of battery to fuel pumps???. Also Cdi box if no spark??
Ist I need to determine if fuel or spark.. Owner says car shuts down as if switch was thrown, doesn't seem to run out of gas. Will always restart, sometimes backfires with restart.I thought I would hardwire fuel pumps to start with, and go from there.
Old 03-18-2012, 04:25 PM
oilonly's Avatar
930 Fuel Pump Fuse Overload - The Solution
'87, Modified WUR, Billet valve, 965 downpipe, Kokeln intercooler, GHL headers, Garrett T04B K27 hybrid, Tial w/.8 bar, WEGO IV, RarlyL8 dual out, LSD
Old 03-18-2012, 04:58 PM
Turbo Hooligan
Bad CDI Box. I had this same problem on my last 930, rewired the fuel pumps, when I sent the CDI box off to be rebuilt, it was def. failing. fixed it, reinstalled it, and no more sudden cut off!
www.d-zug.com
blog.d-zug.com
All these guys do is drive too fast, work on cars, chase ******* and drink.. really no fun at all...
Old 03-19-2012, 05:44 AM
mark houghton's Avatar
Fuel or spark, fuel or spark.....lots of things can cause problems and it sounds like you've researched all the usual culprits. A process of deduction is needed, as you've suggested, temporarily hardwiring the pumps, taking all the relays out of the equation, may help pinpoint. But don't forget that the WUR and AAR get their power from the rear fuel pump relay.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, stock everything else. The result of a massive Pelicanite good will fire recovery effort. Truely an open book, ready for the slippery slopes to modification.
Old 03-19-2012, 07:24 AM
