Hi torque starter
Has anyone tried one of these in there 930? I see lots of good reviews when I do a search, but no turbos.PORSCHE 911 MINI STARTER IMI PORSCHE 912 / 914 / 930 | eBay
87 930 GHL/Rarlyl8/Garretson/GT3582R/1 Bar/Wevo shift, mounts/Meth inj/LM-2/Custom Fuchs/Carrera intake manifold/Xtreme Carrera heads P&P/3.4/DR 993SS cams/ Mahl/Pauter/JE/Niresist/ARP/twin COP/8.25:1/KEP stage 2/twin tials/close 2,3,4th. MS3Pro Evo 500+ HP, BTSOMP Dyno
Old 03-18-2012, 04:45 PM
starter
That seems like a screaming deal. I bought a similar starter for my Ferrari 328 and paid about 400 bucks for it... It spins the car over a lot faster and weighs less. I like it .. For 120 bucks that is dirt cheap.. If my wifes carrera starter acts up I think I will try one.
Old 03-18-2012, 04:57 PM
proffighter's Avatar
I bought this one from our host, lightweight, good quality and powerful:
Pelican Parts - Product Information: PEL-GE-STHT
Roland
930 Turbo '81 Too many modifications to list
Old 03-19-2012, 02:58 AM
I bought the ebay starter last year. works great and easy to install because of its size.
87 carmine red 930 | 57k | B6 modified IC | GHL headers | custom exhaust | VEMS EFI | carrera intake w/ flipped TB | LS2 coils | EBC | K27-7200 (soon to be replaced by GTX3071
Old 03-19-2012, 03:31 AM
I would think the cost combined with the weight savings would make it worth it. As far as powerful, I don't think that's as much of a concern for a low compression motor versus a motor that has 11:1.
John- I blame and thank the longhood boys of Austin
84 911 Carrera w/ 930 t/p,efi'd,dizzy free,HFS turbo[/COLOR], 78 930 RoW no option sunroof coupe, 64 Corvette roadster, 71 911T, 73 911E, 67 Bronco survivor. 71 FJ40, 2001 Boxster
"Illegitimi non carborundum"
Old 03-19-2012, 04:41 AM
Kartoffelkopf
Spenny_b's Avatar
Does anyone know if this starter is the same as for a 965?
I've had fun-and-games with my local auto-parts store, as the p/n they have listed for a 1992 MY 965 actually ships the wrong Bosch item....there are electrical contact differences on the solenoid.
The old knackered looking starter I have has a Bosch p/n of 0331 303 158 658<---this has 3 terminals
Whilst the one I got shipped was Bosch p/n 0331 303 133 -63 <---this only had 2 electrical terminals
Would definitely be interested in getting one of these lightweight units, so long as it has both the right electrical connections and fits a G50/52 transmission.
Cheers
Spencer.
Old 03-20-2012, 06:24 AM
High torque starters ans newer Bosch ones have only 2 terminals, but there is no need for the 3rd anyway. It does lead currency when starting from Pin #15a to cold start valve, switch by solenoid. Newer simply do this direct by incomming currency at pin #30. So just fit both cables on same pin.
Roland
Old 03-20-2012, 07:15 AM
Cheers
Spencer.
Spencer,
The Hi-Torque / mini starters will not work on a standard bell housing G50/52 due to the need to have a long shaft extension and the pinion support. If your G50/52 has been shortened you should read this thread:
Hi Torque Starter - HELP
It can be done but it is a PITA.
Richard.
RSR Replica - http://forums.pelicanparts.com/porsche-911-technical-forum/472762-rsr-update.html
930 Cab - ex-IA car, 3.4L, 1.2 bar, G50
996 Turbo - X50.
Old 03-20-2012, 04:04 PM
I don't have any experience with the one shown in the link however I do have quite a bit of experience with the Hi-Torque starter sold by our host. I data logged the RPM of a new Hi-Torque starter and a new Bosch OEM starter and the RPM's were about the same (~380 rpm). This was on a newly assembled (tight) 930 engine with 98mm cylinders (3.4L). The little Hi-Torque starter sounded strong and given the weight savings, it was a no-brainer. I don't have any experience regarding how long it will last however overall it looks very well built.
I hope this helps,
Richard.
996 Turbo - X50.
Old 03-20-2012, 04:19 PM
Kartoffelkopf
Spenny_b's Avatar
Ahhh thanks Roland - I was *fairly* sure that given a little bit of head scratching, the newer starter could be fitted, but to be on the safe side, I sent it back and gave the parts store the "challenge" of finding the right item
Originally Posted by motley911
Spencer,
Richard.
Cheers Richard....it was the throw-out I had at the back of my mind - casting memory back to Jonathan's (JBL930) threads on his 993tt transplant with a mix-n-match on gearboxes/bellhousings.
Sorry for hijacking folks!!
Spence.
Old 03-20-2012, 05:44 PM
So does anyone offer one that will work on a 965?
Old 03-21-2012, 09:27 PM
This is a local company who does lots of HIGH hp and world class level racing starters. I contacted them to see if they do anything for a 964 turbo
GPE Competition Starters
I have ran them on my mustangs with great luck.
Old 03-21-2012, 09:38 PM
