Can anyone tell me, as I am new to turbo motors. I have a 1987 930 turbo, do I have to change the oil in the turbo or is fed via the engine or a sealed unit?
Also what is the best oil to use when I change the oil in the motor. I have been told not to use a synthetic motor oil as the motors dont like it but it is really difficult to by straight oil like we used to use years ago. What SAE should the oil be as well, once again I have been told 10w to 30w and then 20w to 40w all a bit confusing. The vehicle is not driven in snow or really cold conditions. Also when I first start car there is a bit of whiteish smoke from the exhauste especially if the car has been sitting for a couple of weeks, it then dissapears after about 30 seconds is this anything to worry about. ? Any info would be greatly recieved. |
Fed via the engine sucked out by the scavenge pump and dumped back into the tank. Smoke on start up is common. Most guys run 20/50 brad Penn or valvoline vr1 or? There are may opinions on which oil to use.
Also it is mandatory for new members to post pics of your car if you have not already, ;-) Welcome to the madness (group). There are a lot of great guys on here. Regards.
Jeremy C. Why's he calling me meat? I'm the one driving a Porsche. (Bull Durham) ----Nothing is far away in this car!--- -2001 996 Turbo |
Wayah Road Warrior
Mobil 1 15-50 here.
Remember ... this is teh Intarwebz .... you are going to get azzloads of different opinions on an oil question
02 996tt White 87 930 GP White (Sold) 87 911 Targa Guards Red(Sold) |
Location: PaloAlto Calif, IndianWells PalmDesert, Japan
Well it depends on your climate, if you look at the factory manual ( that is if you have that still or if it is still with the car. ) You can find some basic info the factory manuals are always good
to start with. However once you start getting into modifed vehicles, or abnormal climate or blue printed motors or high milaged motors you should begin to select a oil that is best suited for your needs. Avoid mixi matching. Because in the South of California we get days reaching 120 degrees F. I'll run a higher viscosity. One thing you don't want to do if posible is run to high a viscosity, this can place stress on your rings etc. During the winter I tend to go with something a little lighter and I have a specific tempreture range I prefer to operate air cooled engines within. 15w50 Mobile ( as mentioned already by shadetree930 ) 0w50 ENOES or their 5w40. 10w60 Castrol / RS / TWS or Castrol Classic Oils. Motul makes a lot of great products too, they too have a 15w50.
Taze em..TAZE EM ALL!! A man that builds a thousend bridges is a bridge builder, but a man that sucks one ( blank ) is a ( blank ) sucker. It looks like the 4th of July from my rear view, how about from your view? |
Forced Induction Junkie
I use a 50/50 blend of 20-50W V-Twin Mobil 1 and 20-50W Mobil 1. Use syn's from now on since this;coking in spray bars
My $0.02 and peace of mind.
Dave '85 930 Factory Special Wishes Flachbau Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P |
Using Vr1. I would use synthetic, but I don't know when the last build was done if any. VR1 is readlily available at Auto Zone and cheap when they have their sale.
If you have a cat then I wouldn't use it because of the ZDDP.
John- 78 Slick Top 930 "Illegitimi non carborundum" |
If not synthetic, then go with the highest ZDDP you can find (unless, of course, you're still running with a catayltic converter).
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ. |
Mobil1 straight 40. No problems yet 7+ years. But then again, depends on climate.
On my 1976 930 I put Castrol TWA 10/60.
Best Regards Jesper
1969 911T "The White Lady" Stainless DANSK 1976 930 "The Phantom" RarlyL8 aka The Beauty and the Beast |
I swear by Redline 20/50
