All these things are worth knowing and would drive you nuts trying to diagnose. We did have oil both sides of the turbo tho in the initial failure. I have just beeen poking my fingers inside the exhaust blades looking for oil this time - since it came out my Zork last time.
I have a K&N over my intake housing. And to be fair, I have not yet run this thing hard out since it being put back together. Thanks Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-) |
Guys, I have been asked to clarify what type of turbo this is, specifically. It is a modified 3LDZ - I assume a Higher Flow, but I don't know that this equates to a HF 3LDZ, which apparently is a specific mod on the 3LDZ. Brian may be able to clarify exactly what the designation of this turbo is.
Thanks Alan
Crotchety Old Bastard
I call it a 3LDZm. I don't believe the words "high flow" are copywritten but they can be confused for the K27 variant carrying that suffix. For the purpose of clarity, the 3LDZ is the OEM turbo for the 1975-1989 930 and the K27-7200 is the OEM turbo for the 1991-1994 964Turbo, aka 965. They are completely different turbos.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
Ok thanks Brian, I think the query was whether this turbo is an HF 3LDZ as I believe there is a proprietary HF series?
And how about this - about 2 hrs after posting the above that all is well with the turbo, I now have a puddle of oil on the floor. maybe the turbo is telepathic. I checked about 2 hrs ago inside the blades, no oil. So I bolted the Zork on and dropped the car to the floor. I walk past 2 hrs later and now I have a puddle. Aaargh. Alan
False alarm. Turbo still dry. Was residual oil draining from the Zork.
Man this Turbo stuff is nerve wracking, even when the car is still on the hoist. Alan
Banned
I think it has been well established, through various threads on this board, that it is very difficult to mod turbos with any consistent rate of success. This is something that, previous to my own turbo experience, I had not given any thought to. I have learned a lot about this over the last four years or so (as have others who have read these types of threads with any interest)!
Glad it is looking good so far, Alan, but like you said, the garage test doesn't meant too much, and it will be interesting to see how your turbo holds up in the coming months! |
FYI:
3LDZ turbocharger is officially "obsolete." BorgWarner does not produce bearings or seals for the 3LDZ used on the 1976-89 930 / 911 Turbo engines, and they are long since out of stock on these basic rebuild parts. Once their stock of other spare parts (compressor wheels, etc.) are used up -- that's it. There are other 3LDZ turbos used on other engines, but their bearing and seal dimensions are not an exact match to those used on the Porsche-specific 3LDZ. The bearing kits and rebuild kits you see on eBay? Junk, out of spec. Most of the rebuilds and hybrids? Junk, build on out-of-spec parts. I know of fewer than a handful of turbo rebuilders who know how to piece together a Genuine BW seal kit and supply correct spec bearings to correctly rebuild our 3LDZ, and it is not cheap. Unless you're restoring an all-original car, or stuck in a "modified stock" class (as the poster above is stating), then it makes no sense to put any money into a 3LDZ.
Chris Carroll TurboKraft, Inc. Tel. 480.969.0911 email: info@turbokraft.com http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft |
Thanks Chris, I am now brimming with confidence.
I guess the question then is, since the bearings/seals seem common to the modified and stock 3LDZ, does the same issue arise with simply any 3LDZ re build, modified or not? Alan
Smart quod bastardus
I hate to think that I might as well junk my k27S if it ever wears out and not to rebuild it because of part availability and have to spend lots of Benjamins on a new Garret turbo. Dam this is a depressing post.
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max ---"When you're racing it's life! Anything else either before or after, is just waiting" |
Success! Had a track test day last w/end. No issues and car is HAULING. Been waiting for oil leaks from Turbo. Nothing - not a drop.
Looks like my friends re-assembly has fixed it. But it does make the whole job seem a bit fickle. Thanks as usual for all the good info. Alan
This is a HUGE problem, more than ever with the parts we are getting from reputable suppliers, which implies that we must investigate all or most crucial parts to make certain that they are of the highest quality. Even the suppliers (big names) don't know that the parts in question are in fact "fakes" else from China. Many out there are running fake bearings in their so called freshly rebuilt transmissions and don't even know it! Same with the rod bearings...and gasket sets...eek! So be aware and diligent and ask lots of questions; don't just "assume" that all is well and lovely with the parts that you get for you Porsche. It's all a BS game, for sure, nowadays.
Thread Tools | |
Rate This Thread | |
