930: 3.3 IC on 3.0 engine
Hi there,
I'd like to install the 3.3 OEM IC onto my 3.0 Turbo engine. Now I have the IC itself and valve housing below the IC from the 3.3 engine but it still doesnt quite fit. Does anyone have any ideas where the 3.0 inlet manifold differs from the 3.3 one? And whether it is possible to do the job I am intending to without buying too every single part of the 3.3 engine? Thanks, Dennis |
You'll need the entire intake manifold from a 3.3 to make this happen. The angle of the 3.0 throttle valve is distinctively different from a 3.3.
Youll need the intake manifold, 3.3 BOV assembly, up pipe adapter and the IC to make it all happen. Luckly, these 3.3 intake parts are always for sale in the classifieds on Pelican Be sure to replace the o-rings.
1977 930 GP White 2011 BMW 335 D (thats right a Diesel 425 ft lbs of torque) 1973 1/2 911 T GP White (sold way too soon....ugh) 1976 911 S Silver (my very first 30 years ago) |
Crotchety Old Bastard
The throttle body sits in a slightly different plane on the 3.0 as compared to the 3.3L engine. A 3.3L intake manifold will put things where they need to go.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
Ok, so last thing to get is the manifold. Last question: Does it make sense? Any ideas how many hp I might gain or how much boost I might drive with the IC?
Thanks a lot! |
fact: intercoolers do not add horse power, intercooler allow for more power to be made intercoolers cool the air intake temperature allowing for more boost and timing and lowering the chance of knock and detonation. i hope i said that right, i know what im trying to say, but sometimes its harder to type on a blackberry. |
Look at the figures
What do you think happens with the torque of an engine, and hence hp, on the same manifold air pressure with different air inlet temperatures entering the combustion? some examples of mass vs. temperature on SAME manifold air pressure Temp. °C = Kg/m3 0°C = 1.251 kg 50°C =1.057 kg 100°C = 0.916 kg 200°C = 0.722 kg 300°C = 0.596 kg Hot air expand and hence giving higher or same manifold air pressure with less air molecules. Cold air holds more air molecules on same map pressure. Combustion needs the air molecules to burn fuel. Keeping the same manifold air pressure and same volume of fuel injected, colder air will burn more of the injected fuel in the combustion due to higher quantity of air molecules. We never succeed to burn/exploid full potential of the gasolin (you could find other fuel fluids having greater burn rate than gasolin). Greater combustion per cycle makes more torque per cycle and as torque x rpm (cycle) = power, you will gain more hp theoretically. If intercooler is working correct, cold air makes more hp on SAME manifold air pressure due to the higher volume/mass of air molecules entering the combustion. However you will properly not notice it on a 75-77 930 due to OEM setup. Having said that, you are absolute right on the fact intercooler is needed if you want to increase boost on a respectable modern CR to control detonation. But alone lowering the temperature on same manifold air pressure will have a positive effect on torque and power theoretically. Controlling detonation is another story/benefit and the single most efficient reason to use a IC. Remember, we boost (increasing manifold air pressure) to increase number of air molecules, we also increase air molecules by lowering the temperature (as one of the benefits from cold air manifold intake). Air molecules = torque. |
God I love it when we talk technical stuff like air molecules, density and temperature!
Absolutely correct. You see the same (relative) impact on a NA car when running down the road on a brisk winter morning, as opposed to blasting through the desert on a hot summer day. Guess which scenario the car runs strongest at? As Brian said - "The throttle body sits in a slightly different plane on the 3.0 as compared to the 3.3L engine" - I wonder if it would be do-able to leave your 3.0 manifold in place and briddge the gap from the IC with a somewhat flexible silicone hose adaptor? Of course, you'll still need to install a BOV somewhere.
Mark H. 1987 930, LSD, B&B shortneck Intercooler, K27 7006 turbo, Tial WG, Kennedy Stage 1 PP, HKS boost controller to 1.0bar, Boost recirc manifold delete, BL adjustable WUR w/boost enrichment delay, LC-1 AFR and G3 analog gauge, Greddy boost gauge, MSD6AL and 8762 boost retard ignition, K&N cone air intake, Fabspeed single outlet muffler |
Prrrreeeettty cool stuff!
I'm with you Mark, I love this forum... |
Brando
Just for some real world back to back comparo....
I just installed an intercooler to the same engine you use last week, and while my intercooler is a reallly nice one, I'd bet you'll see an increase in seat of the pants power over the same engine, boost, and timing as before. For me, the diffrence was longer lag with snappy onset and then more power overall. It's worth it. I'm getting more power no doubt about it. My azz says about 20hp, but I have a really good intercooler.
Turbo powa! 1977 911s 1977 930 engine sc cams DFL, Combustion chamber coatings 915.61 trans garret gt30r .82 a/r obx headers garratson intercooler WMI system MSD6al two carrera coolers .8bar spring (stock). |
Non User
I would say the comparable diffeerence would be driving a stock 3.0 on a HOT day vs. cool 50 deg morn. Definitely a difference in power, probably better described as 'pep'...
Sorry Mark, just noticed the repeat.. Anyway you guys get the drift... Back to my cave...
Infraredcalvin - AKA Pat '76 Turbo Carrera - Factory LSD, 1 bar spring, Kokeln Turbocharger, Rarlyl8 muffler, '83 930 brakes '75 914-4 GT track project '12 Jeep Grand Cherokee SRT8 |
Brando
BTW mark is right. I Bridged that gap with some silicone coupler/hose and hose clamps and it works great.
