Wide body, molester.
Fuel puddling in upper intake
964t
What would cause fuel to puddle in the upper air intake? Any insight would be great..
91- 964T, It's upkeep treats me like a skinny white kid in prison, but it does give me a reach around every now and then by letting me drive it. That's not so bad. |
Chain fence eating turbo
First hint to get EFI...........so it won't start for weeks like mine
![]() Sarcastic bump.... |
Your warm up reg most likely blow the diaphragm , and is blowing fuel up through the breather and in to the air box and dripping onto the intake manifold , I have CIS and I love it, sorry tippy , easy to replace the WUR just make sure that you get the same exact model or look up Rarlyl8 ( Brian ) for an adjustable one , it will come Pre set to factory specs , but adjustable if you want better proformance, but you need to do a lot of research before tackleing that,
Helio
1986 944 turbo -first car 1997 993 Cab 6 speed-sold 1992 964 C2 turbo SOLD, 911GT ,CIS, 428 fwhp 450 trq, Carrillo rods, 964 cams, TT retainers,7.5 comp 1.1 bar boost 320 ml black fuel head 009 injectors, 044 pumps, 60-1 T4/T3 dual scroll turbo Last edited by heliolps2; 04-15-2012 at 06:23 AM.. |
Does the Brian Leask WUR work on turbocharged cars?
Metal Guru
RarlyL8 or direct to Brian Leask are your sources for a rebuilt, adjustable wur. With an adjustable wur you will like the performance improvement once you have your car set up.
Paul B. '91 964 3.3 Turbo Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb |
Yes. Thicker diaphragm ![]() Let's get it on!
"What would cause fuel to puddle in the upper air intake? Any insight would be great.."
Never heard of an upper intake.. what is that? If the WUR fuel metering disc sprang a leak and it's vent hose is still where it should be the air cleaner housing will have fuel in it. "Thicker diaphragm more boost." They don't have a thicker diaphram made.. they sandwich 2 stock ones together if you ask for that $30 something modification. |
I didn't know that, I thought I read a few places that it was a special thicker one. Maybe I am mistaken.
Smart quod bastardus
Whats the odds of getting a stock WUR to run fine in a modded 3.4 liter with SC cams and stock euro fuel head and injectors? Only added fuel mod is water/meth kit.
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max ---"When you're racing it's life! Anything else either before or after, is just waiting" |
Metal Guru
When I took it apart there was only one diaphragm in it so I assume that's exactly what he does.
I was told about sandwiching two origonal diaphrams together to increase durability running higher boost by another CIS rebuilder.
I had Brian Leask make my WUR adjustable around 4or 5 years ago and it works great. It's amazing how adjustable it is on a CIS Flowtech modified fuel head. I've never taken it apart to see if he made a thicker boost enrichment diaphram and didn't mean to imply thats how he does it. |
So just an update, it IS thicker, Brian has them made.
Crotchety Old Bastard
Yes BL has thicker diaphragms made.
Yes I stock adjustable WUR's pre-set to your modifications. Yes you can have a stock WUR internally adjusted to match your fuel needs, we handle that as well. Both are plug and play. If fuel is pooling in your air intake I assume you have the stock air box and the WUR vent plumbing is intact. Pull the vent line and verify that is where the fuel is coming from. The fuel is pooling in the air intake and not the intake manifold yes? Your '91 C2T WUR should have a part number ending in -160. Verify that as well. Are you running higher than stock boost? Is the car now running badly? If fuel is in the air intake then likely the WUR diaphragm has blown, if fuel is pooling in the intake manifold then likely the cold start injector is leaking. Neither of these is a common problem.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
RarlyL8, thanks for the reply
I am running 1.1bar Yes it was puddling in the AIR intake. The car wasn't running badly before. It did have a progressively worsening hot start issue. One day it wouldn't start at all for 10 min then finally I managed to get it running and it was running horribly and the front fuel pump got really loud which lead me to think it was the fuel accumulator. I was wrong. When I was changing out the accumulator I removed the air intake and then found the fuel puddling in it. It was indeed the WUR and I did get one from Brian.
Well done. I love it when a plan comes together!
Kevin 1999 911 Carrera [996]-Vesuvius Grey Metallic |
Thread Tools | |
Rate This Thread | |
