solarispete's Avatar
930 Turbo hesitates
Hi guys,
I have a 1985 930 Turbo Euro.
Lately, noticing esp when warm that the Turbo boost hesitates... (not a smooth boost). My mechanic was thinking the turbo is leaking, and suggests rebuilt. He also suggest that I do the WUR as well. Is this a common thing to fix to remedy the Turbo boost problem? To replace both, is it alot of manhours?
Peter
Old 04-16-2012, 07:55 AM
wjfk32's Avatar
Had a similar problem recently(start with the simple things first) after upgrading the intercooler..Double chk-hose lines-connections..Chk AFR-Readings..Tightened down the intake-can,Still didn't get the feel what I wanted..
Then took the plugs out--A little rich looking..Put in a new set..I also dialed back my fuel-dumping--HKS-AIC...
No more hesitating..
Walt
Old 04-16-2012, 08:46 AM
Change in fuels composition (winter/spring...) might due that to our engines/plugs , including acting up of "old" WUR; I'd not look into the turbo itself - yet. It really doesn't take lots of MH to swap them.
Old 04-16-2012, 12:33 PM
Hi guys,
I don't think it's the plugs. I recently just had a tuneup with oil change which replaced all the plugs, distributor, oil, air, fuel filters. And I have had both fuel pumps replaced as well as the coil.
Old 04-17-2012, 06:43 AM
wjfk32's Avatar
Originally Posted by solarispete View Post
Hi guys,
Hopefully are gapped to specs...How do i know?
Also--If u can swap a CD Box..(test)
Old 04-17-2012, 07:15 AM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
