hipdoc's Avatar
Shaking steering wheel.
My 79' street 930's steering wheel starts to shake quite a bit the faster I go. When i hit 80-90mph it shook so much I had to slow down quickly. I've lowered it front and back and put a bump steer kit but did not change any bushings or shocks. Is it the alignment or needs bushings?
Old 04-19-2012, 11:21 AM
Banned
Most of the time, a shaking steering wheel indicates a wheel/tire problem (out of ballance, bent, out of true or cracked wheel, damaged tire - bulged/chunked) . . . have you checked any of this yet?
Old 04-19-2012, 11:34 AM
Crotchety Old Bastard
RarlyL8's Avatar
Stupid question, are the lug nuts tight?
Old 04-19-2012, 04:48 PM
Hukdunfoniks's Avatar
My 930 does the same thing even though my alignment/camber has been checked. New tires solved the issue but I can feel the shimmy slowly coming back.
Old 04-19-2012, 05:07 PM
j930's Avatar
mine did this until i had it balanced properly. insist on having it balanced properly. i know when they did mine the second time they overinflated the tires to seat them on the rim. i think the term was a centerline balance? I'm not sure though.
84 930 Slant
15 Sonata 2.0T
08 Ram 1500
15 Ram Eco Diesel
Old 04-19-2012, 06:58 PM
Tinkering Pays!!
mooney265's Avatar
Good point! Don't ask how i know...
Sent from my MB855 using Tapatalk 2
LIVN80S - - Red '79 Porsche 930 Steel Slant Nose Conversion [in 1987] w. 46k miles 3.3L; 964 Cams; K27HF @ 1.0 BAR, with Garrettson Intercooler; Rarly Zork; CIS Flowtech Fuel Head & BL-WUR.
Old 04-19-2012, 08:24 PM
Depending on how slight or violent the "shaking" is the wheel bearing tension could also be suspect and is often overlooked and very easy to adjust.
Old 04-20-2012, 04:36 AM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
