help,...no power to fuel pumps
1980 930 3.3
new fuel pumps, were working fine before car was torn apart,...now engine reinstalled and i am not getting any power to my fuel pumps
no idea where to start...
all new red relays installed, installed old relays and still nothing.
Old 04-19-2012, 01:40 PM
Hey Jim,
I know it's a dumb question, but did you forget to put the fuses back in?
Old 04-19-2012, 02:11 PM
Originally Posted by icemann427 View Post
Hey Jim,
what fuses are we talking about
Old 04-19-2012, 02:26 PM
i just realized i am not hearing that high pitched wine from the ignition unit,...
stock bosch unit
Old 04-19-2012, 02:41 PM
PrimeMvr's Avatar
Are you using the stock overboost sensor on the intercooler? If so, is your IC well-grounded? Try grounding the wire that goes to it.
I use that wire with a switch inline to ground to turn the pumps on and off when checking pressures.
87 930 - Black - 3.4L/964 cams/K29/Powerhaus IC/6AL-2/B&B dual exhaust/MTX-L/235-315 Toyo R888/18" Kinesis wheels/Big Red brakes/LSD
10 997.2 Cab - Speed Yellow
83 SC Cab - Guards Red [SOLD]
17 NSX - Nouvelle Blue
Old 04-19-2012, 02:47 PM
oilonly's Avatar
Over boost switch connected or wire grounded? Intercooler grounded? Do you hear the fuel pumps pressure up when turning the key, before ignition?
'87, Modified WUR, Billet valve, 965 downpipe, Kokeln intercooler, GHL headers, Garrett T04B K27 hybrid, Tial w/.8 bar, WEGO IV, RarlyL8 dual out, LSD
over boost is connected, correct white wire,
i dont hear fuel pumps, they are not getting power
i am not hearing that wine from bosch unit though,...is this related?
Old 04-19-2012, 02:50 PM
oilonly's Avatar
That I don't know. Some more relays to think about on this thread.
1989 930 - Won't Start - No Fuel
Old 04-19-2012, 03:10 PM
i dont have that yellow relay, my car is a 1980, it just has a regular red relay there...
if i unplug green plug from air meter and jump 30 &87a i still get nothing...
i cant find a way to test my CDI unit online...but it is deff not whining like it used to
Old 04-19-2012, 03:17 PM
oilonly's Avatar
Just double checking, your fuse is good plus intercooler is grounded. Maybe relay under seat came loose? Just thinking out loud. CDI question I can't answer.
Old 04-19-2012, 03:22 PM
fuse is good, intercooler is grounded, no relay under seat
Old 04-19-2012, 03:50 PM
TT Gasman's Avatar
Intercooler grounded? Sorry for the dumb question but can someone explain this to me? This might explain the intermittent problem I'm having with my tach needle.
Doug
Houston, Texas
997 TT 550RUF
'86 930
Old 04-19-2012, 06:51 PM
PrimeMvr's Avatar
The overboost sensor needs a ground to complete the relay circuit for the fuel pumps. Since the sensor screws into the IC in most installations, the IC itself needs to be grounded. This is usually accomplished by the mounting hardware, but if you have all rubber mounts and hoses you can end up isolating the IC and the sensor is no longer grounded.
I don't think that is your tach issue. It's more likely a wire on the back of the tach or the purple wire coming off the CDI. I accidentally tweaked the coupler on that wire doing a valve adjustment once and my tach went dead.
Old 04-19-2012, 07:27 PM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
