Stupid
OK so I'm stupid. Need to take apart my washer lines at the T to blow things out as the driver side sprayor isn't working. Passenger side is fine.
So tell me how to free up the one piece brass clips that the factory uses on all of the hose joints on my ROW 85 Turbo Thx |
long noze pliers in the fold and you spread it open a bit... to put it back on, you can use 90 deg cutter pliers to squeeze it (not regular cutters as they will cut the metal) but the process of removing it might damage it... I know you can buy new ones of these and the proper pliers to install them on but I could not find them so I went with the springing type
David 1985 Black 930, K27 7006, Garretson Intercooler, Adj boost, TB: 23 - 31mm, bielstein sport shocks, ER polybronze bushings front and rear, ER monoball joints front and rear with offset camber plates, 935 X triangulated strut brace, raised spindles, racing bump steer kit 1981 Black 911sc (sold) |
Thread Tools | |
Rate This Thread | |
