rear wheels locked?....
ok, trans was rebuilt by gary fairbanks, 1980 930...
trans is free to move both inner flanges and main shaft, in and out of gear... I had the car jacked up on stands for about 3 months, i washed the "brakes", calipers and surrounding area with hot soapy water and degreaser.... i tried to turn the hubs to connect the CV joint bolts and the hubs are LOCKED SOLID... put wheels on and tried to rock back and forth with two people, NOTHING placed wood between wheel studs and jacked up a bit, NOTHING is it possible the Ebrake welded itself to the hub? from sitting and water... if i start the car and put it in gear and let the clutch out, you can feel the clutch grab and car will start to stall, as rear wheels can not turn.... rear of car is still in the air. |
ok this is fixed...e brake shoes were locked up and rusted a bit
Thread Tools | |
Rate This Thread | |
