proffighter's Avatar
BTW Here is what Barry from SDS sent me for changing from F to C (Did not yet):
EM 3/EM-4 SETUP MODE TEMPS
Unplug hall sensor plug from ECU.
Power up the ECU with the programmer plugged in.
Momentarily ( second ) short out pins 6 & 7 on the hall plug port on the ECU using a wire or setup tool (provided by SDS ). See drawing below.
You will see SETUP TEMPSENSOR in the programmer window.
Choose one of the following by pushing the +1 button until the correct sensor is reading in the window.
GMF
DALE F
FORD F
GM/CHT F
BOSCH F
CHT/BO F GM C
DALE C
FORD C
GM/CHT C
BOSCH C
CHT/BO C <<<<<
Push +10 to exit setup mode
Roland
930 Turbo '81 Too many modifications to list
Old 04-24-2012, 03:25 AM
what? me worry?
TimT's Avatar
Setting the cold start tables is one of the most difficult things to accomplish when tuning a EFI install, since you only have a few tries a day to make adjustments.
Another problem here is that we are trying to compare maps from different manufacturers it is a multi-variable mix of apples,oranges, peaches and durian.
Some systems uses TOG (Time on Gamma) or injector pulse width in milli seconds... and a decay function for warm up enrichment..Others have tables with temps and percentages, other have tables with number that don't make much sense..
Someone posted a set of tables that are 8 bit values for percentages...
0-255 = 0-100% in 8 bit speak.
Here are some tables that give conversions for 8 bit to %
8bit-percent value conversion
I find that its easier for me to deal with pulse width, and a temp value decay when tuning cold starts/warm up..
who are those guys? <<< ( Butch Cassidy and the Sundance Kid)
Rent a GT3RS from us!! Call or e-mail.
Transportation and Track support
Rudtners Racing
'69 911 GT-5
'75 914 GT-3
Authorised Haltech seller and installer
Authorised Unichip installer
BBS wheels
Fikse wheels
Redline motors oils
Swepco
1500 hp chassis dyno
Old 04-24-2012, 05:50 PM
Wer bremst verliert
JohnJL's Avatar
Hi Tim,
You are certainly right on all those points. I've tried to simplify my question down to the pulsewidth during cranking in cold temps, I seem to have the post-cranking enrichments set close to correct. Once it catches, it usually stays running. Its that first catch that's eluding me and as you point out you only have a few opportunities a day since subsequent tries can be influenced by leftover flooding, fouling or diminished battery voltage/amps from previous tries.
Any suggestions you have for 55lb injectors @ 40psi in temps of 0 - 15 C?
John
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 04-25-2012, 04:24 AM
Rocket Scientist
What does the 100 for "IDLE" mean? Are you running an Idle Air Control (IAC) valve of some type, like a linear solenoid IAC, or stepper motor IAC? If so does the 100 mean closed or open? The reason I ask is that hard starting when cold can mean that you need more air. Have you tried working the throttle while cranking cold?
Old 04-26-2012, 05:05 PM
R.I.P.
drmatera's Avatar
very good point speedy....
Old 04-26-2012, 06:20 PM
Wer bremst verliert
JohnJL's Avatar
100 for IDLE means my idle stepper valve bypassing the throttleplate is open. It works like a choke when starting. In closed-loop idling it adjusts continuously to get the engine idling at a given target speed.
I spent another unsucceful day yesterday in 3-6 degree temps and no joy. Adjusted injector opening from 6ms (what the engine uses when idling cold) all the way up to 35ms. I get more and more caughing as fuel increases but still will not catch. The flugs arent fouled, I have a function in the ECU thal allows me to test fire each spark plug and each injector. I get a "caugh" or "boom!" when each plug is fired between starting tries, indicating to me there is both fuel vaporized and that the plug is firing.
Old 04-28-2012, 03:25 AM
John,
Have you checked the voltage while cranking ? Does your system have a voltage compensation map ? If you are cranking up the pulsewidth and the engine is not flooding, low voltage may be an issue. I have a couple of Haltech EFI conversions that will never fire when cranking if battery voltage drops too far, but fire up immediately with a new fully charged battery. Some systems have a minimum voltage to open the injectors and a weak battery, bad connections or a worn starter is all it takes.
Paul
Old 04-28-2012, 04:34 AM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
