9dreizig's Avatar
Location: Reno NV, Bay Area during most weeks,, Kids still in NH
Send a message via AIM to 9dreizig
Ok just jumping back into this.. just started it up, and I did the usual "carb cleaner" test,, sprayed all around with no change in idle speed..
Then I leaned out the throttle body adjuster and as I did the idle went up..
Couldn't adjust it out any measurable difference with the idle screw..
how would I check that aux air valve??
"Todd"
98 Tahoe ,2007 Saturn Vue
86 930 black and stock, 80 930 blue tracdog
91 Spec Miata (yeah I race a chick car)
"life"ll kill ya" Warren Zevon
Old 05-07-2012, 04:03 PM
oilonly's Avatar
Before you start it when cold, remove the hose that goes into it, use a flashlight and see if it is open (it should be) If it is warm and running squeeze the hose that goes into it to make sure it is closed (it should be closed when warm. Or remove hose to it when warm and engine off to make sure it is closed.
'87, Modified WUR, Billet valve, 965 downpipe, Kokeln intercooler, GHL headers, Garrett T04B K27 hybrid, Tial w/.8 bar, WEGO IV, RarlyL8 dual out, LSD
Old 05-07-2012, 05:10 PM
mark houghton's Avatar
Pinch the hose going to it to completely stop the air flow. If the valve is stuck open, then cutting off the air will cause the idle to drop.
And/or, pull off the hose and take a look inside at the opening, car hot and car cold. The opening should close down when she's hot. And/or, take the AAR off the car, put it in the oven at 150 for awhile, check the opening, then put in the icebox for awhile and check it again. Pretty crude, but it will tell you if the thing is functioning or not.
Shoot, while typing OilOnly beats me to the punch!!!
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, stock everything else. The result of a massive Pelicanite good will fire recovery effort. Truely an open book, ready for the slippery slopes to modification.
Old 05-07-2012, 05:14 PM
oilonly's Avatar
Yeah but you suggested the icebox/oven route. I like that approach.
Old 05-07-2012, 05:19 PM
Banned
So have you ruled out the decel valve? The carb cleaner test would not tell you if the diaphram was torn etc. . .
Old 05-07-2012, 06:13 PM
9dreizig's Avatar
Ronnie, I am pretty sure I took the decel valve out when I removed all the air pump junk (didn't I ?).
Since it was running well when I took the engine out, I'm thinking something didn't get connected again ??
"Todd"
Old 05-07-2012, 06:32 PM
9dreizig's Avatar
Ok just went out and have this to report..
took off the hose on the AAR, could see a small hole opening.
started it and it died when I pulled the hose.. however when I plugged the hose it revved right back up and ran well but fast,, I could regulate the speed by regulating the amount of air that was allowed to be sucked into the hose. Meanwhile the AAR was sucking air like crazy..
ideas?
"Todd"
Old 05-07-2012, 06:50 PM
Todd, if you pull the hose then keep in mind that the other end it's connected to is the intercooler. You pull the hose off the AAR, and the IC will now have a MASSIVE air leak (thus, your engine shut down as would be expected). Somewhere, I've got a picture of what the opening should look like when stone cold. I'll find it and post it.
HA!!! Found it.....Note that the opening is around 90% open. It's on a disc that rotates freely with spring tension against it. If you were to run ethe car until fully warm, then all but the bottom "slot" of the opening would be closed. If you were to completely block the hose that connects to the IC, and completely plug the opening to the AAR, then your idle should drop to around 500 with a stone cold engine.
Old 05-07-2012, 06:59 PM
9dreizig's Avatar
ok so yes it's open when cold,, and yes the massive air leak into the intercooler is what I closed off and allowed it to continue running.
So I'm thinking that the symptoms I'm seeing are not reflecting a bad AAR,, just the opposite right ?
Oh and it idles fast hot OR cold
"Todd"
Old 05-07-2012, 07:04 PM
I wouldn't rule out the AAR just yet. The question is......is it still that far open when it's hot? Thus, it would draw too much air into the manifold post-throttle body and cause a high hot idle.
Two things can prevent it from closing completely when hot: (1) the AAR is not getting any electrical power (it's on the same circuit as the rear fuel pump relay) and thus will never heat up enough to close off. Or (2) it's just plain old stuck, i.e., mechanically worn out/gummed up inside.
I still want to know, if you have all the hoses connected correctly and when she's fully warmed up and idling too high, does the idle drop when you completly pinch the hose closed? (I use a pair of long nosed pliers to do a good pinch job).
Almost done diagnosing...now for a glass of vino, a good book, and bed time.
Old 05-07-2012, 07:25 PM
Banned
The decel valve doesn't have anything to do with the airpump system - not saying you didn't remove it but that cought my eye in your sentence . . .
Old 05-07-2012, 07:28 PM
9dreizig's Avatar
Thanks guys, I'm going to call it for a night as well. I'll pick this up next weekend.. (traveling this week)
T
"Todd"
Old 05-07-2012, 07:35 PM
Your symptoms point to an air leak somewhere downstream from the throttle body. As Ronnie points out, the decel valve is one possibility - being that it's connected post-TB. It's that gold saucer-shaped thingy with large (1/2"?) hoses connected to it.
Since your car was idling fine before you pulled the engine, then either you left something disconnected or failed to plug a hose somewhere after removing the air pump junk. That's the most likely scenario. The AAR....yes, a malfunctioning one will cause this, but it would be a coincidence that it's failed since puting the engine back in. You never know, though.
Old 05-08-2012, 04:35 AM
9dreizig's Avatar
I agree Mark, I'm sure this whole thing is a result of a brain fart..
This weekend in between track days I"ll pull the intercooler and do a complete evaluation of all hoses etc.
"Todd"
Old 05-08-2012, 07:01 AM
9dreizig's Avatar
Ok had some time today,, Here's what I did..
made a bung clamp for the LM-2 (welded the bung to some steel stock and then to a set of vice clamp plier,, works great)..
So from there, tuned it up to a perfect 13.7 idle.. still couldn't get it down to 1800 rpm
stayed there when warm,, then took it for a spin.. went pig rich upon start up (WITHOUT going into boost). It does still develop full boost..
So looks like I'm back in search of a vacuum leak..
BTW, recently had put new seals on intake, all injector blocks are good no cracks..
Also did the "spray test" with carb cleaner,, no noticeable change in rpms..
HATE looking for these things!!
"Todd"
Old 05-28-2012, 05:41 PM
9dreizig's Avatar
Ok guys working on it again this weekend. Im' changing out all the hoses that go to the decel valve ,, any idea how to check the decel valve?
"Todd"
Old 06-02-2012, 03:51 PM
Banned
Probably the easiest thing to do is to remove the decel valve (if it is still there), cap all the ports (including the tiny one on the throttle body) and then see if the idle is still high and unadjustable . . .
Old 06-02-2012, 04:04 PM
9dreizig's Avatar
should it be open or closed when cold ? I can see into it..
"Todd"
Old 06-02-2012, 04:48 PM
Banned
The decel valve is not temperature operated - vacuum created by closed throttle moves a diaphram within it and thus opens a port and allows air to bypass the throttle plate . . .
Old 06-02-2012, 04:54 PM
oilonly's Avatar
My opinion, post a few pictures of the engine so we can see how you have it set up. JMHO
Old 06-02-2012, 05:42 PM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
