Front license mount
So I have this nice newly painted virgin front valence with a split screen in the middle. I have to mount a front license plate, no legal room to moan about aesthetics, design, big brother, et alia.
While I am loathe to drill holes in the car, anyone have any tried and tested suggestions? It's much easier on later model Porsches as a guy makes a nice mount which screws into the front tow hook slot.
Old 04-29-2012, 10:37 AM
TT Gasman's Avatar
Use the factory front mount, pelican sells them
Old 04-29-2012, 11:30 AM
Mine has an oil cooler opening in the center of the valence too. I stuck a Velcro strip on the top edge of the back of the plate and attach it to the rubber rub strip on the bumper. Believe it or not, it stays well attached even at high speed. I keep it off most of the time (but handy in case I get pulled over) except when the car is parked on the street--no front plate in my state invites a parking ticket.
Jon
'85 930
Old 04-29-2012, 03:17 PM
MikeD930's Avatar
That's too bad you have to mount the front plates. Since it looks like you have an oil cooler up front perhaps drill multiple small holes in the plates (not through the number/letters) to let air through?
MikeD '87 930
Old 04-29-2012, 05:22 PM
Roby466's Avatar
I have seen some people make a bracket that came from under the valence and they could install and remove the plate easily. When the plate was off, only a small 1in wide piece of metal would stick out from under there... not sure where they got that but I too would like one like it. For now, mine is held with zip ties that I cut everytime I go to the track...
1985 Black 930, K27 7006, Garretson Intercooler, Adj boost, TB: 23 - 31mm, bielstein sport shocks, ER polybronze bushings front and rear, ER monoball joints front and rear with offset camber plates, 935 X triangulated strut brace, raised spindles, racing bump steer kit
1981 Black 911sc (sold)
Old 04-29-2012, 07:34 PM
TT Gasman's Avatar
Didn't notice the oil cooler, in that case I wouldn't worry about it.
Old 04-30-2012, 04:02 AM
Thanks. I looked at the OEM one and decided that I will just make one up on my own - perhaps two thin brackets coming out from the top of the screen on each side of the break. Finding something behind the valence to attach them to should be no big deal.
I had a 76 930 years ago and the PO simply held the license plate on with two sheet metal screws into the rubber strip. I can do better than that.
Thanks again.
Old 04-30-2012, 06:12 AM
Wayah Road Warrior
Shadetree930's Avatar
Do you happen to have all the bits & pieces from the old OEM bracket?
I am in need of the two white plastic anchor inserts that go into the valence as well as the two square black rubber mounting bushings that are part of all the bits associated with the front bracket mounting system.
02 996tt White
87 930 GP White (Sold)
87 911 Targa Guards Red(Sold)
Old 04-30-2012, 06:45 AM
I've gone native
Tt surgeon's Avatar
I would use the stock mount w multiple holes drilled in it. No front plate equals a hassle in NYS.
'07 997.1tt
Blk/blk 600hp, bad to the bone
Old 04-30-2012, 07:28 AM
Sorry, no, don't have it, but you can find variations of the white blocks at Autozone.
Old 04-30-2012, 08:09 AM
I was stopped by the Highway Patrol for no front plate. I asked why motorcycles do not have to have a front plate. He told me because the were only issued one plate that's why. This gave me a idea. I went to DMV and asked what plate my car was eligible for that only one plate was issued. Dmv said my car was eligible for a Special Purpose Plate. Only one plate is issued. There are some restrictions but my car is not a daily driver so it's not a issue. In Oregon it's a permanent plate (no renewal and no emissions test)
Old 04-30-2012, 01:48 PM
nreed's Avatar
If you Google retractable license plate...
Since your 930 is not as low as mine this might work...
Altec Retractable License Plate Holder - 400EU
Norm '86 930
AEM Infinity 6 - Twin Plug 3.6L - DBW - JE Pistons/LN Eng. Cylinders - Pauter rods - GT3 Crank - GTX3584RS - ID1050x Injectors - Ported Intakes - Custom Intake Manifold, exhaust and intercooler - 993SS cams
HRE Wheels 560R 8.5x18 ET25 (Front) 11x18 ET0 (Rear)
Old 05-01-2012, 05:40 PM
speednme1's Avatar
ok that's cool....might have to look into that
Old 05-01-2012, 05:59 PM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
