Looking at a 91 964turbo with leak down results of 3% cyls 1 and 2, 15% on 3, and 4,5,6 at 5%. test done approx 1 year ago at 51k miles, now has 54k....any advise? Don't think i can get a leak down test done where car is and prior closing deal. Tks
My wrench says anything less than 10% cold is fine (because they typically drop if measured hot). It's faster, easier (and thus cheaper) to do the test cold.
If they get more than 10%, they re-do the test hot - and that figures over 10% hot are not encouraging. So right there, it's not clear whether the figures you have were obtained hot or cold? 3-5% are nice numbers, hot or cold. 15% could be nothing - and may not even read that now - or could be a problem you need to address.
'77 S with '78 930 power and a few other things. |
Kartoffelkopf
Irrespective of whether you have a (potential) problem on #3 @ 15%, I'd say you've got a good negotiation point on the basis that it's out of kilter with the other 5 cylinders
...therefore "there's an element of doubt, put yourself in my shoes..."
1993 (MY92) 964 Turbo 3.3 - Horizon Blue - Follow my 964 Turbo project here... http://forums.pelicanparts.com/911-engine-rebuilding-forum/626572-964-3-3-turbo-efi-conversion-using-syvecs-life-racing-engine-management.html On Instagram (along with other stuff) as @spenny_.b #spennybengineproject |
I would think that would warrant at least a 10k adjustment probably more. I'm not an expert but all cylinders were checked under like conditions and the one at 15% likely has an issue
84 930 07 Exige S |
Thanks for the advise and comments, my gut instinct told me to pass on this one. Closed the deal
Yesterday on a 92 with 33k miles, recent 30k svc and mechanically perfect. Will be posting pics Once it arrives, meantime Ill be enjoying my 88 Carrera as weather begins to cool a bit in Texas. |
