964 Turbo ABS pump trouble shooting
Hello Folks,
Noticed a small amount of fluid under neath my driver side front bumper. Took the car to Porsche and was told I need a new hydraulic ABS pump ( $1700 + L)
Had them button up the car until I have time to look into it. So last night went out and noticed the fluid coming out right where the brake switch screws in ?
Can some one confirm that I only need a switch and an O-ring rather than the entire ABS pump.
Old 05-12-2012, 03:32 AM
Got Boost?
IMONBOOST's Avatar
I wish I had an answer for you as I am having ABS problems as well, although no leak that I know off, and they seem difficult to troubleshoot without replacing parts. $$$$$$.
If I where you, start by taking the spare tire, battery, ABS Cover, battery cable cover that runs over the floor pan and inspect that you don't have any starting corrosion due to the leak.
Good Luck.
"The only motivation to make you go race after race, travel after travel, is winning. The possibility that you have for winning. If you don't have that, nothing else can make you work."
-Ayrton Senna-
Old 05-12-2012, 06:01 AM
Thanks for your reply and yes me and Porsche service tech both looked and every thing was just fine. The leak had just started so I was lucky there We did take out the battery and other stuff and rinsed the area with water.
Old 05-12-2012, 06:11 AM
I've gone native
Tt surgeon's Avatar
Perhsps a Indy Porsche shop rather than the dealer could fix rather than replace.
Other than pads n rotors, brake systems I don't Meds with too much.
Old 05-12-2012, 06:53 AM
IMR-Merlin's Avatar
Just a little side note, if you need to clean anything that has brake fluid on it and don't want to harm the finish further (electrical excluded) all you need is a spray bottle with tap water. The water will break down the fluid, simply wipe it off with a cloth or compressed air. No need to use harsh chemicals like brake cleaner.
Old 05-12-2012, 07:19 AM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
