tadman's Avatar
CSV plug
CSV control start valve pictured. Which side is brown wire on and or does it matter? Plug has two sockets, notched center on one side which allows the plug to go on one way. Car is 78 930.
On my CIS system I deleted the supplemental air valve and thermo time switch. Put in a switch to activate CSV manually for cold start, guess maybe 2-3 sec. Only down side I see is keep foot on pedal until warm or put in a throttle cable. Anybody try this, how did it work?
Thanks, Tad
Old 02-21-2013, 04:16 PM
tadman's Avatar
Found the original connector red/black and yellow. Looked at 1978 flow chart so red black and yellow went from TT switch to the CSV triggered by relay.
Old 02-22-2013, 09:00 AM
