Oil drip tank for turbo's...Dimension?
Can someone tell me the dimension of those nice stainless steel turbo oil drip tanks?
2275T MS EFI '65 VW Panelvan http://www.vvwc.ca/minstone/ |
Metal Guru
10 cm long x 6 cm diameter or a total capacity close to 8 oz. When my car is shut off for a few hours, I find 7 oz of oil in the tank. I run the stock K27-7200 turbo (I've heard that the ball bearing turbos use less oil). Hope this helps.
Paul B. '91 964 3.3 Turbo Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb |
thx
Thread Tools | |
Rate This Thread | |
