86 930 won't start
Hi all, I have checked a few of the threads, but nothing seems exactly like my problem.
Normal temperature.
Car will crank, may even fire up, and shuts down immediately.
The fuses all look good.
When I turn the ignition on, before cranking, I can hear inside the car the typical whining of the fuel system.
With the ignition on, if I listen to the noises in the engine compartment, there is a sort of a constant whistle very "thin" sound. Same sound in the front compartment.
This has happened before, about 10 years back, and was supposed to have been fixed, but they never told me what it was.
Does anybody have clue?
Old 05-28-2012, 05:07 AM
Sounds like it may be a perma-tune issue. Do you know anyone locally that would let you swap in their ignition box before you have the buy one?
I'm pretty sure that any 8-pin box will work.
Old 05-28-2012, 05:36 AM
Are you referring to the Electronic Ignition box? I may be able to source one for trouble shooting purposes, but last time this happened I'm pretty sure it was an "easy fix" that did not involve replacing parts of that magnitude.
Old 05-28-2012, 05:45 AM
BTW, I've seen reference to an under driver's seat relay, and had a look. There is nothing in there except for what seems to be the wires for the power seat.
Old 05-28-2012, 06:12 AM
I've gone native
Tt surgeon's Avatar
Fuel pumps?
Ck fuse #6 from the windshield.
Old 05-28-2012, 08:27 AM
Figured it out
Thanks to all, I switched the 2 relays in the trunk and the car started.
Old 05-28-2012, 08:45 AM
HFR_Racer's Avatar
Ignition is easy to check. Lay a plug out on the engine block and have someone crank it over while you watch. The CDI boxes usually fail completely not partially. I'd pull your fuel pump relays before you do this.
Next... Check for fuel. You can jumper your fuel pump relays in the boot area to check that your pumps are working.
Use the SEARCH button. Many many threads on this subject matter already exist.
Read up on it and make yourself a checklist. Once you've done the research then small issues like this become easily diagnosed for the DIY mechanic. Good luck with getting her running.
Old 05-28-2012, 12:06 PM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
