Clutch Chatter Help
After the engine rebuild my clutch chatters on take off in low. I have reajusted the clutch several times with no improvement. With the engine rebuild I replaced the TOB, disc and pilot bearing. Flywheel and pressure plates looked good and measured flat. Did not have this problem prior to the tear down. Any ideas or suggestions are greatly appreciated.
Banned
I experienced the exact same thing you are describing about 4-5 years ago - my "fix" is posted in the following thread -
clutch making the car shake? |
Banned
Thread Tools | |
Rate This Thread | |
