Wide body, molester.
H20 LOL's Avatar
JF I'm getting ready to install a kit I have left over from my viper. I noticed your air filter right ontop of the air flow meter , what is the part # for that filter and where do you run your WUR vent tube too?
91- 964T, It's upkeep treats me like a skinny white kid in prison, but it does give me a reach around every now and then by letting me drive it. That's not so bad.
Old 06-04-2012, 05:48 PM
R.I.P.
drmatera's Avatar
hey Jim, have you tried running straight meth? Give it a try and let me know what you think
Old 06-04-2012, 05:51 PM
I don't remember the air filter part number. Brian Bodart recently installed one on his car maybe he has the K&N part number. The opening fits the CIS perfectly. It might be somewhere on a different hardrive than the one I'm on right now.
Since that picture was taken I installed a 90* fitting in the top center of the air filter and attached a hose that goes to the WUR vent and the gas tank vent line. I have no charcoal cannister filter in the gas tank line, I have an oil filter inline from the turbo scavange pump mounted where it was so that works good for me.
Darin, I havn't tried straight methanol. The fire hazard kinda scares me with that and methanol burns invisable. Alot of Indycar drivers were burned back when they ran methanol and they changed to E85 so you could see the fire if it happened.
Old 06-04-2012, 06:22 PM
Forte500
Jim, that is the temp sensor just at the bend and near the BOV....which is why I am putting the injector directly after the intercooler. What is your point about "wet coating" the Carerra intake?
Do you think the "juice is worth the squeeze" of this project ?
Old 06-05-2012, 12:06 AM
Brando
quattrorunner's Avatar
So I installed my system tonight finally. I used my washer resavore and placed the pump in the engine compartment because they didn't supply me with enough red line. I used drip line for the feed line which fit perfectly. Anyway, couple questions for those who know or have been there.
Rsrfan told me that when his light is on, he feels the wmi like a light turns on. I didn't get this when mine initiates. My system comes on at a predetermined pressure and then raises till full boost.
Second, though tonight is kinda cool(55) I didn't really notice a much difference but maybe it's because it's not hot outside tonight? What do you guys think?
Also, have you noticed that the car runs cooler with the water/meth system? Thanks.
Old 06-05-2012, 01:04 AM
I think your WMI project it worth it.
I wouldn't put the WMI nozzle right after the intercooler before all that tubing though, thats definately the wrong place for it.
I don't understand why you want to do that or even consider it when there's plenty of room at the other end of that 180* pipe right before the TB.
Mounted there it wouldn't be wetting out the entire inside diameter of all that pipe, the BOV, and air temp sensor.
I think you can also buy a screw together injection nozzle bung that fits in silicone multiply hose. I know they make those for nitrous oxide injector nozzles so a WMI nozzle would work in one too. That way you can get it right over the throttle body which is best for single injector WMI.
I would have to write a long boring description about dry flowing and wet flowing intake manifolds that are origonally designed for dry air flow only and I'm not sure you'd understand it.
You can search and read laminar flow on the internet. Dry flowing is air only and wet flowing is flowing air with water mist, methanol mist, water mixed with methanol mist, or wet gasoline mist and nitrous oxide gas from a throttle body nitrous oxide injection kit.. mixed and suspended into the air flow through the intake manifold.
Short vesion is with the turns and distance in the casting right below the carrera throttle body, the two log type plenum chambers, ducting and turns in the 6 carrera manifold intake runners the air and water methanol mist travels through before reaching the intake ports - because of laminar flow and turbulance around corners some of the water and methanol fine mist droplits are going to come out of air suspension and coat the interior walls of the manifold turning into a thin liqued flow along the interior surfaces instead of remaining entirly suspended as fine mist droplits in the air flow carried into the intake ports with the intake air.
When that happens you get some liqued water and methanol in large droplits going into the combustion chambers along with all the finely atomized stuff and that can cause some misfiring and power degradation by contaminating the air fuel mixture so not all the gas is burned during combustion.
You can dry flow WMI or nitrous oxide and gas by installing individual injectors in each carrera manifold intake runner right before the intake port. More expensive, complicated, more maintenance, and you'd need a progressive controller running the pump with that configuration but it will work better.
A stock pancake 930 manifold should work better for single injector TB WMI in theory because there is so much less interior volume to fill with air.
Mount your WMI injector as close to the throttle body as possible or it will not work as well and will probably shorten the life of your BOV and air temp sensor.
Old 06-05-2012, 09:02 AM
Brando
Anyone have louder pops right after full throttle then closed throttle situations with 50/50 water meth? Trying to adjust it out. It's really loud bangs like explosive.
Turbo powa!
1977 911s. it's cool
Old 07-04-2012, 10:39 AM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
