Fuse box label needed.
Does anyone have a hi-res scan of the label for an 87 930 for the fuse box that they would like to share? I could print one out on my plotter if I had a scan that is readable at the normal size. Have seen pics of some on the site but no good when I plot it out as the resolution just isn't there.
Pelican used to sell them but no longer does. |
I just tried to scan my 1987 label and it is too long to fit in the scan space - I guess I could scan it in two parts and you could put them together? Let me know and I will do that and then email it to you. It seems to be good resolution as it is very readable even when enlarged quite a bit.
I posted my label in a separate thread:
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/680799-aav-delete-now-having-fuel-issues.html Mine's an '88 930, so I'm guessing it's the same. Still not sure, though, why it doesn't show the fuel pump relay locations... Oh, and sorry for the slight burn mark on the label... that was where my fuel pump fuse got a bit hot and melted it! If you want a higher resolution scan, let me know. I can scan it again. |
Well, I just checked the part number on Pelican, and the label I have is for a 911, not a 930... guess that solves the problem with the fuel pump relays. Looks like I'm in the market for a 930 label as well...
I can scan when I am in the office next week if you still need them.
Hello guys, I also would like a clear copy of the label , can some email it to me please, thanks
helio.losee@yahoo.com |
Ronnie's.930 Sent a PM. If it works I'll fix it up and send it out to who ever needs it.
Don :) |
Hi Don - I sent you some scans. Let me know if you need more . . .
Ok have the label joined. email me @ defreest@comcast.net if you want a copy.
Not sure the models yrs but it's good for my 87 930 http://forums.pelicanparts.com/uploa...1339283979.jpg |
You can order this.. The PET has the number.
| All times are GMT -8. The time now is 11:56 PM. |
