WARM UP REGULATOR lines what options are there
I replaced my WUR ( warm up regulator ) lines over the weekend with the best hose I could source locally ( carburetor / vacuum hose) .
It took about 1 minute for the hose to burst, I thought it was a faulty hose so I replaced it but the new hose also burst within a minute ![]() I tried to contact special T auto but they seem to be unavailable, something to do with a delorean car show. any other options other than oem . Is it possible to fabricate new line? What size line and fittings would be needed? Thanks |
Carburator fuel line is low pressure and can not be used for fuel injection. Vacuum line has no reinforcment and can't take any pressure or it'll pop.
The WUR control pressure is hydraulic fuel pressure isolated from the rest of the CIS fuel pressures by a small fuel supply orifice leading to the control pressure cavity above the control plunger in the top middle of the fuel head and it's around 30psi when cold and around 60 psi when warmed up after a few minutes. That hydraulic fuel pressure pushes down on the top of the control plunger against the air flow meter sensor plate mechanical linkage that is pushing up on the bottom of the control plunger as you open the throttle and engine speed increases. The fuel line you need has to be rated for fuel injection pressure levels and gas and alcohol fuels. It is usually rated up to 300psi and CIS is up to 100psi in it's fuel supply line. The hose used for the WUR supply and return lines is thick walled and really small inner diameter and you won't find that in generic auto part stores. It's different than common fuel injection line. Go to a hydraulic hose supply store or go mail order from someone that knows what you need for this application. Using the wrong hose on those tiny barbed banjo fittings and not knowing what you're doing with a high pressure fuel system is a major fire hazzard. |
930-110-302-05 Supply line from fuel distributor to warm-up regulator. $101.50 from our host.
930-110-305-03 Return line from Warm up regulator to fuel distributor. $42.25 from our host. Both parts will come from Germany and probably take a week or two. Check with your local Porsche dealer or Zim's also. I bought mine from PP. Toby
Toby Pennycuff Dallas, TX 1979 930 Petrol Blue Monster 1968/1973 911S MFI #73 - Tweety Bird. 911 PCA Club Racer. E Prepared 2001 GT3 Cup #77 - O M G! |
I relocated my WUR and needed 15" lines to reach back to the FD. I took them to a hydraulic repair shop in town and they crimped the old fittings back onto new high pressure fuel lines (not hydraulic oil lines) and charged me a whopping 20 bucks. They've been in place for over a year with no issues.
87 930 - Black - 3.4L/964 cams/K29/Powerhaus IC/6AL-2/B&B dual exhaust/MTX-L/235-315 Toyo R888/18" Kinesis wheels/Big Red brakes/LSD 10 997.2 Cab - Speed Yellow 83 SC Cab - Guards Red [SOLD] 17 NSX - Nouvelle Blue |
or this https://www.belmetric.com/hoses-smooth-high-pressure-oem-c-14_139.html?zenid=8aq14rap7o35torkp5a8qvatm0 Last edited by speednme1; 06-06-2012 at 04:33 PM.. |
Crotchety Old Bastard
If you can measure the ID, OD, and wall thickness I may have some polyamid hose that size.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
Hello,
Thanks for the replys, I just wanted to update this. I finally had a chance to go down to Aeroquip dealer to get my fuel lines, they did a great job. I also had 1 of my injector lines renewed with my old fitting. Brass crimp fittings were used and it they look great. thanks again for all the help ![]() ![]() |
Thread Tools | |
Rate This Thread | |
