Transmission Fluid - what is the best?
Yes, I have seen the threads, aside from the conversations, the only thing I read about is Sweepco...
Really? That is not what I had on my 911. It was something else but I cannot recall the name. It was recommended because, it was said that it provided better impact protection for the gears...I never had a problem from that fluid in my 915 tranny.
Now I have a 930, I am having to do maintenance on it. I am looking for something other than the stock sweppco because I will be putting this car on the track.
So what other racing fluids are recommended for this 930/36 with LSD?
Signature Phrase " CATCH ME IF YOU CAN"
1988 Porsche 930 "Squerly" Built by "Porsche Doc"
1974 Porsche 911 (2003 - 2012)
2000 Boxster S (2006 - 2008)
Old 06-08-2012, 02:01 PM
I track my 79 930 for the last 5 years and have used Swepco 201 and have had no issues...If anything it might be time to change the fluids it is time to drain and refill. I might switch to 210
I wait to hear others chime in
Scott
1979 930 - Black on Black and in the woods
"My third child that will cost more in the long run" :shock:
Old 06-08-2012, 03:39 PM
DW SD's Avatar
Hayden from WEVO made the swepco 201 recommendation to me as well. I run a few track days a year and have an LSD. He suggested no additives, either. I trust Hayden's recommendation.
Doug
1971 RSR - interpretation
Old 06-08-2012, 03:44 PM
GL5 LSD gear oil for Porsche steel synchros. Swepco 201 seems to work good in my transmission, and I hear this stuff is real good too.
Pelican Parts - Product Information: KEN-LSD-7745
Back in the eightee's it was Valvoline.
Old 06-08-2012, 04:45 PM
Swepco here too. And I use it in my 915 on a track car that use to see oil temps in the 240 range in 95+ heat. Shifting use to get a bit bulky at those temps but it held together and never failed.
Tinker
Old 06-08-2012, 09:24 PM
Well I finally found the bottle I used before and it was
Red Line, Lightweight Shockproof Gear Oil.
I never had an issue with this oil, and I never see anyone talk about Red Line.
Or anything else....
But the Swepco 201 seems to be the choice...
Old 06-09-2012, 06:57 PM
beancounter
jwasbury's Avatar
I recently changed my gearbox oil and used Motul Gear300LS. It meets/exceeds GL5 spec. So far very happy with this choice. I don't know what was in the gearbox before, but it was a red color (possibly Redline?).
Jacob
Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690
Past: 2009 997 Turbo Cab / 1979 930
Old 06-10-2012, 12:03 AM
M5guy's Avatar
I used to run a zero weight gear oil in the gearbox when I raced Formula Vee...anything for the extra 1/2 horsepower. Clearly not the choice for a 930...
Old 06-10-2012, 03:47 PM
Driver
Noah930's Avatar
I'm also running the Swepco, which is no help in answering your question.
1990 Black 964 C2 Targa
Old 06-10-2012, 07:40 PM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
