87 930 leaking oil, help! With pictures
Not sure where this is coming from... It has always had a few drips but recently it has gotten worse. IT is getting to the point where oil is getting on the paint under the whale tale and starts to visibly smoke at the stop lights. ( how embarrassing)
I cleaned it up and and let it run at idle till it started dripping. The above pictures show all the problem areas...problem is i still can't tell where it is coming from. I figured i would just start by changing out the valve cover gaskets and see if that helps. I hope my turbo isn't blown. It all runs fine but is starting to leak so bad I'm afraid it might catch on fire.
Help! pelican parts forum gurus your my only hope....
Old 06-14-2012, 04:55 PM
50 views no responses so I'd suggest you do try the valve cover gaskets first. Make sure to get the new nuts with the gaskets from our host here, and if you're going through the bother of having them off, you might as well check your valve clearances and make sure no head stud nuts are rolling around in there.
These things start weeping after a while, most commonly towards the front of the engine near the breather cover and oil sender area, but your leak appear to be more towards the rear... perhaps a dented oil return tube or the cam box covers. But try the valve covers first (and you may get a better look when you are in there doing that).
Ken
1986 930, 1969 Mach1, 2003 540 Sport, 2016 R1200RS
Old 06-14-2012, 07:20 PM
Banned
The oil in the last pic could be coming from the small oil hose that feeds the cam chain tensioner on that side . . .
Old 06-14-2012, 08:29 PM
Look into the turbo intake. Could be seals are going bad
Old 06-15-2012, 02:52 AM
OK, will do on the valve covers and check valve clearance...I have them in hand ready to change. I just have the OEM covers should i get the "silicon" ones instead? Also, Does the turbo have seals? Ive loOKed for these at the host site but cant find them. I have a k27 turbo not sure what they could be.
Old 06-15-2012, 04:21 AM
copbait73's Avatar
Don't know if you are a newer to owning air-cooled Porsches or just want to drive dry ones. Regardless the best way to track the source is to wipe down the engine. Put tracer dye in the oil and look for the source with a black light.
Go to the l local auto parts store and they can set you up. Without this you can replace a lot of expensive parts on advice of others and still not solve your problem.
Old 06-15-2012, 04:30 AM
I've gone native
Tt surgeon's Avatar
I've seen the oil line on the top of the turbo leak just like that, check simple stuff first before you start pulling off the turbo.
'07 997.1tt
Blk/blk 600hp, bad to the bone
Old 06-15-2012, 05:13 AM
mark houghton's Avatar
UV tracer dye....I didn't know such a thing existed. Good idea!
Yep, put on a pair of crusty old coveralls, jack up the car, and crawl around under there armed with a pair of safety glasses and a couple spray cans of engine degreaser. Hose 'er down good, let it sit, and hose 'er down with water. Drip dry, start, look for leaks, drive, look for leaks, fix leaks.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, stock everything else. The result of a massive Pelicanite good will fire recovery effort. Truely an open book, ready for the slippery slopes to modification.
Old 06-15-2012, 12:31 PM
oilonly's Avatar
Yes check that. On my car the line to the cam cover was lose and the oil was leaking onto the tin then landed on top of the heat collector. Just like the bottom picture.
'87, Modified WUR, Billet valve, 965 downpipe, Kokeln intercooler, GHL headers, Garrett T04B K27 hybrid, Tial w/.8 bar, WEGO IV, RarlyL8 dual out, LSD
Old 06-15-2012, 02:05 PM
awesome thanks guys, whats the best way to get to the line to the cam cover? From the bottom? Do I need to remove anything to see it? Also, does anybody know about the third picture? It all comes from that little scalloped area on the right? This is located on the right side of the engine on the just posterior to the lower valve covers. Any thoughts on that? thanks again, sorry for being such a numb nut.
Old 06-15-2012, 03:08 PM
aerodyn930's Avatar
Hello, The oil leak you are inquiring about , (the one leaking at the scalloped area of the chain housing) is very likely the o rings that seal the chain housing to the cam housing, Very common, If you remove enough items it can be done with the engine in the car but I don't recommend it , The cams will need to be re-timed as you are removing the cam sprockets to access this area,,
Hope it helps, Lou
Old 06-15-2012, 03:22 PM
oilonly's Avatar
I noticed it when I removed the intercooler and up pipe. Oil was pooled on the engine tin and was coming down the cam cover where the oil line threads into it.
Old 06-15-2012, 06:49 PM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
