Order Online or Call:
888-280-7799
McAfee SECURE sites help keep you safe from identity theft, credit card fraud, spyware, spam, viruses and online scams
Porsche | BMW | Mercedes | Audi | Volkswagen | Saab | Volvo | Mini
  Search Pelican Parts:
View Cart | Project List | Order Status |  Help
Kirk911SC's Avatar
Angry Pig rich under boost
Okay, help me out. What's going on here?
My car is now blowing brown/black smoke under boost and hesitating/stuttering at the upper end of the boost cycle (as the wastegate opens).
I had the boost set for 0.9 bar and backed it down to 0.8.....seemed to lessen the smoke a bit, but the stuttering/hesitation is still there.
I've checked for leaks after the turbo, figuring there's a boost leak. Can't find anything wrong. I tried spraying starter fluid around all the o-rings and hoses while the car was running.....no effect. WUR?
Car idles smoothly and drives fine.
The only other thing to mention is that I recently installed a K&N cone filter in place of the air cleaner assembly.
- '87 930
- Garrett T-04 60-1 hybrid turbo
- SC cams
- B&B stainless exhaust and muffler
- Andial fuel enrichment
- Adjustable boost controller (0.9 bar)
- MSD 6AL ignition
- '00 Dodge Viper GTS - Steel Grey - Yep...a domestic.
- '87 930 - Guards Red - Sold
- '82 911SC - Grand Prix White - Gone
- '78 928 - Silver - Long gone
- '97 BMW 540i - The daily-grind-mobile
Old 06-16-2012, 05:16 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #1 (permalink)
9dreizig's Avatar
Location: Reno NV, Bay Area during most weeks,, Kids still in NH
Send a message via AIM to 9dreizig
nope,, classic vacuum leak... did you try checking all of the nuts that hold the intake down ?
"Todd"
98 Tahoe ,2007 Saturn Vue
86 930 black and stock, 80 930 blue tracdog
91 Spec Miata (yeah I race a chick car)
"life"ll kill ya" Warren Zevon
Old 06-16-2012, 05:22 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #2 (permalink)
Kirk911SC's Avatar
The actual manifold? Nope.
I'll check them tomorrow. Why would it loosen up now?
Old 06-16-2012, 05:24 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #3 (permalink)
aerodyn930's Avatar
The insulator blocks take a set and sometimes crack , When checking the nuts on the manifold lubricate them first then back them at least 1/2 turn, be carefull not to overtorque them for the reason mentioned earlier,
But... Try disconecting the manifold press switch for the Andial fuel enrichment, secure the wires and test the car, If this improves the situation under boost then you need diagnose the enrichment unit by measuring the control press drop when the unit activates,
Hope this helps,, Lou
Old 06-16-2012, 06:08 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #4 (permalink)
mark houghton's Avatar
Boosted air leak (as in turbo plumbing pipes/hoses and/or o'rings). Let air escape, and the ratio of fuel already delivered against the lost air will cause a pig rich condition. Even though you've done the starter-fluid-around -the-o'rings test, it is possible that things are sealing just fine until you pressurize them. You may not see any leaks when cruising non-boosted (such as at idle). Pull the IC, visually check the rings, inspect all vacuum and turbo hoses for splits or cracks. That's painless, free, and easy....put that to bed first, then move on to other possibilities.
Mark H.
1987 930, LSD, B&B shortneck Intercooler, K27 7006 turbo, Tial WG, Kennedy Stage 1 PP, HKS boost controller to 1.0bar, Boost recirc manifold delete, BL adjustable WUR w/boost enrichment delay, LC-1 AFR and G3 analog gauge, Greddy boost gauge, MSD6AL and 8762 boost retard ignition, K&N cone air intake, Fabspeed single outlet muffler
Old 06-16-2012, 06:25 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #5 (permalink)
Kirk911SC's Avatar
Insulator blocks are about a year old. I replaced them along with a bunch of gaskets, hoses, etc. the last time I had the engine out.
I've pulled the IC and checked all the seals and hoses.
Old 06-16-2012, 06:41 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #6 (permalink)
I've gone native
Tt surgeon's Avatar
Wrap the IC joints with duct tape, if the symptoms go away, you have your answer re the o rings.
Mine did the exact same thing. Even after I replaced the o rings, I still wrapped a thin black strip of duct tape around each joint just to be on the safe side, belt n suspenders.
Old 06-16-2012, 07:15 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #7 (permalink)
Kirk911SC's Avatar
Wrapped the IC joints in duct tape; checked that manifold nuts were tight; disconnected fuel enrichment; and paid closer attention to what's happening.
- Hesitation/stuttering worse as gears go up (i.e. almost non-existent in 1st, but VERY noticeable in 3rd). Car pulls pretty hard in 1st, but gets progressively worse in higher gears. I tried a full throttle pull in 3rd on the highway and once the boost started to come up it felt like the car was going to stall - coinciding with brown smoke
- Worst of smoke is when letting off the gas under boost, but the smoke starts at about 0.7 bar along with the hesitation.
- No apparent leaks from IC joints or hoses
- Car seemed to run worse with the enrichment off, especially as boost came on
Old 06-17-2012, 07:11 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #8 (permalink)
Ronnie's.930's Avatar
I wonder if one of the two fuel pumps is not working (therefore, not enough fuel pressure) - could be a cause of the high rpm/high load rough running but I guess that wouldn't explain the black smoke, however. Maybe you shoud try fiddling with the realays for ****s and giggles anyway?
Old 06-17-2012, 07:15 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #9 (permalink)
Kirk911SC's Avatar
Hmm....I can check that. Front fuel pump is about 3 months old. Rear...who knows?
Old 06-17-2012, 07:23 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #10 (permalink)
oilonly's Avatar
Do you still have your oxy sensor hooked up?
'87, BMC air filter, Billet valve, 965 downpipe, Kokeln intercooler, GHL headers, Garrett T04B K27 hybrid, Tial w/.8 bar, WEGO IV, RarlyL8 dual out, LSD
Old 06-17-2012, 07:43 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #11 (permalink)
Kirk911SC's Avatar
No O2 sensor, and no cat.
Old 06-17-2012, 07:44 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #12 (permalink)
Now available:  101 Projects for Your Porsche Boxster!
9dreizig's Avatar
I agree,, first thing you need to do is get ahold of your fuel pressures..
"Todd"
Old 06-17-2012, 07:46 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #13 (permalink)
Kirk911SC's Avatar
Bit of an update.
This morning I booked an appointment with a Porsche specialist for tomorrow.
Tonight I decided to switch the cone air filter back to the stock assembly.
Took the car for a drive and it's much better.
Ambient temperature is somewhat cooler than the last few times I've driven it, but no more than 10C difference.
Smoke and hesitation is there, but reduced. Cone filter seems to be affecting the metering plate??? Weird.
Still going to take it in tomorrow and see what he has to say.
Old 06-18-2012, 05:37 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #14 (permalink)
Old 06-18-2012, 06:12 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #15 (permalink)
Try to not be so obvious when you copy and paste someone else's words in an attempt to slip-in a link to some bull**** website!
Old 06-18-2012, 06:36 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #16 (permalink)
Without a calibrated onboard wideband AFR gauge to see how rich it is at different rpms and boost levels you can't really diagnose it.
A CIS fuel pressure gauge kit and mighty vac for checking the boost CPR and the distributor advance/retard pots while using a timing light are good to have.
If everything else checks out you may just need to install an rpm switch and vacuum solenoid in the boost pressure hose going to the bottom of the CPR so it doesn't lower control pressure making it run richer until around 4600 rpms or maybe higher like up around 5200 rpm or so in your car.
An adjustable WUR/CPR from Brian Leask with the seperate cold start, cruise, boost, and boost threshold adjustments may help too.
Old 06-19-2012, 09:13 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #17 (permalink)
Kirk911SC's Avatar
Thanks for the ideas.
It'll be interesting to see what the tech comes up with today. He was going to start with the fuel pressures. Supposedly he has many years experience with 930s and he has an excellent reputation amongst other owners in this area.
Old 06-19-2012, 09:41 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #18 (permalink)
Have you checked to make sure the K&N isn't interfering with the mixture adjustment screw? I did the same install and had to cut quite a good size notch in the base of the K&N so it wouldn't interfere. If the problem began after installing the K&N and improved when you took it off, I'd bet a cold one that the K&N was pushing down on the mixture screw.
Richard
1982 930, K27-7200, Ruf wheels, Leask WUR, Tial WG, WEGO IV AFR, RarlyL8 headers & single out muffler, TK IC coming soon
2007 BMW X3 3.0si
2004 BMW R1100S
Old 06-19-2012, 10:12 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #19 (permalink)
Kirk911SC's Avatar
Just got off the phone with the mechanic. He's taken the car for a short drive.
He said it doesn't seem to be a fuel issue, but a boost leak somewhere. Said it's way down on power.
For starters he thinks the wastegate (stock) is opening too soon or leaking. He'll be focusing on the car tomorrow. I've been eyeing a Tial anyway.
Wastegate issue doesn't explain the smoke though??
With regards to the mixture screw - yes the filter was pushing on the screw when it was installed. Sort of pushing sideways on it, not down. I thought the allen screw (spring-loaded) had to be depressed fully to have any effect on the mixture?
I'll update as I know more.
Old 06-19-2012, 11:14 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #20 (permalink)
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Copyright 2011 Pelican Parts - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
