962 962 is offline
962's Avatar
Clutch Recommendations for Twin Turbo
87 G-50....What Clutch would you go with ?
What will last ?
Old 06-19-2012, 12:53 PM
Infidel
JBL930's Avatar
Sachs 890nm is what all the European tuners use, i use it in mine and it's a great clutch
Jonathan.
87 930, 993 turbo engine, RS Tuning 520PS/515lbf-ft, Arrow Rods, ARP hardware, Solid lifters, G50-50, RS Flywheel, 890nm Sachs clutch, RSR coil overs all round, 993 C4 calipers front, 930 fronts on the rear, Ruf Speedlines.....
Old 540 BMW, XB12S Modified, for being a total hooligan
Old 06-19-2012, 03:37 PM
GJF GJF is online now
Slantnose from HELL
GJF's Avatar
There is also a Cup pressure plate from SACHS that is 1050nm also. Should be good for 800+
It changes from time to time.....
Old 06-19-2012, 04:19 PM
Slantnose from HELL
GJF's Avatar
FVD Brombacher Online Shop - FVD1169281 - Increased clamp.force, 240mm , bis 1050NM max. Drehmoment - CLUTCH → Tuning → Pressure Plate
Slantnose from HELL
GJF's Avatar
Or a SPEC stage 5 part#SP 525 is good to 1378NM or 980 ft/lbs or 1000+ HP it is the flywheel, pressure plate and disc.
Old 06-19-2012, 05:03 PM
Slantnose from HELL
GJF's Avatar
SPEC Clutches & Flywheels: Auto Parts, Domestic, Import, Truck, Racing, Drifting :: Results By Car
Old 06-19-2012, 05:08 PM
Infidel
JBL930's Avatar
Those are some seriously heavy duty clutches, good info.....
What power level are you aiming for 962? I guess that'll be the deciding factor
Jonathan.
Old 06-19-2012, 05:13 PM
David's Avatar
Kennedy Engineering.
2014 Cayman S
2011 Cayenne Turbo
Old 06-19-2012, 05:44 PM
Slantnose from HELL
GJF's Avatar
Kennedy is good for 650HP. For about the same cost a stock C2 turbo will give you the same clamping force and be slightly better quality. SACHS would be my first choice. If more power than that the above units can provide, then multi disc is the only way.
Old 06-19-2012, 06:17 PM
Slantnose from HELL
GJF's Avatar
I have been s l o w l y working on a twin disc setup for my car using SACHS 215mm and another version using 240mm pressure plates. Biggest problem is, although it last more than twice the life of a single and increases the holding power by 500 ft lbs, the diffent bellhousing depths of some modified transaxles won't allow them to fit. They are custom made per application.
Old 06-20-2012, 08:15 AM
Kennedy Engineering KEP kit?
Old 06-20-2012, 04:25 PM
962 962 is offline
962's Avatar
Hi, Johnathan:
HP to be determined.
Going Kennedy.
Thank-you all for your feedback.
Old 06-24-2012, 04:52 PM
