-   -   push or pull fan for fender oil cooler (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/685104-push-pull-fan-fender-oil-cooler.html)
zaidigonzo 06-22-2012 06:04 PM
I upgraded my trombone cooler to a mocal cooler and now Id like to add a fan. What do you use? Push or Pull? I have the scoop so I assume pull but not sure......
Thanks!
infraredcalvin 06-22-2012 06:26 PM
You need a push type, I bought an elephant racing cooler that came with a generic fan, by flipping the fan blades it would go from pull to push. Not really impressed as the blades were only designedly to go one way. Regardless,it works well and operates off a thermostat.
Btw, install the fan on the opposite side of the tire side, this is why you need a push to work in conjunction with the scoop.
zaidigonzo 06-22-2012 06:47 PM
Cool. Thanks!
So push blowing to the front of the car not blowing towards the tires correct?
Wont it work against the air flow produced while the car is moving?
I am here: http://tapatalk.com/map.php?e3n53r
zaidigonzo 06-22-2012 07:34 PM
ok. got it. should have read the end of your post! Thank you
infraredcalvin 06-22-2012 10:19 PM
Yeah, I thought about it and had to edit my post. The fan is about an inch thick, if it's on the tire side the tire will hit it when you turn too sharp. Probably rip the whole cooler off...
Ken911 06-24-2012 06:55 AM
Always use a push fan for coolers. The heat from the cooler will burn up the fan motor usually if it's in a pull configuration.
zaidigonzo 06-24-2012 08:04 AM
Good points. Thank you!
Miguel Antonett 06-25-2012 03:53 PM
push and blowing with the flow - towards the rear.
zaidigonzo 06-26-2012 04:04 AM
Cool. Now to figure out how to stuff a small fan between the fender and cooler....! Any size recomendations? Its a mocal cooler from Pelican Parts
I am here: http://tapatalk.com/map.php?43t5ha
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
Copyright 2020 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
