push or pull fan for fender oil cooler
I upgraded my trombone cooler to a mocal cooler and now Id like to add a fan. What do you use? Push or Pull? I have the scoop so I assume pull but not sure......
Thanks!
1984 ROW 930 turbo with rarly8 exhaust, waste gate pipe and HEADERS K27HFS TURBO, B&B IC, 1 bar spring,LEASK WUR with rpm solenoid, fab speed intake filter, front strut brace rennline. MOMO wheel, Innovative afr 16-1 gauge, custom 930 ELGIN cam |
Non User
You need a push type, I bought an elephant racing cooler that came with a generic fan, by flipping the fan blades it would go from pull to push. Not really impressed as the blades were only designedly to go one way. Regardless,it works well and operates off a thermostat.
Btw, install the fan on the opposite side of the tire side, this is why you need a push to work in conjunction with the scoop.
Infraredcalvin - AKA Pat '76 Turbo Carrera #311 - Factory LSD, Sport Seats '75 914 GT clone project '71 914 track car |
Cool. Thanks!
So push blowing to the front of the car not blowing towards the tires correct? Wont it work against the air flow produced while the car is moving? --- I am here: http://tapatalk.com/map.php?e3n53r
ok. got it. should have read the end of your post! Thank you
Non User
Yeah, I thought about it and had to edit my post. The fan is about an inch thick, if it's on the tire side the tire will hit it when you turn too sharp. Probably rip the whole cooler off...
Always use a push fan for coolers. The heat from the cooler will burn up the fan motor usually if it's in a pull configuration.
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's. 2019 Silverado 6.2L |
Good points. Thank you!
push and blowing with the flow - towards the rear.
Cool. Now to figure out how to stuff a small fan between the fender and cooler....! Any size recomendations? Its a mocal cooler from Pelican Parts
--- I am here: http://tapatalk.com/map.php?43t5ha
Thread Tools | |
Rate This Thread | |
