Order Online or Call:
888-280-7799
McAfee SECURE sites help keep you safe from identity theft, credit card fraud, spyware, spam, viruses and online scams
Porsche | BMW | Mercedes | Audi | Volkswagen | Saab | Volvo | Mini
  Search Pelican Parts:
View Cart | Project List | Order Status |  Help
Registered Driver
Helmsy's Avatar
Fixing or replacing is fine but it would be nice to know what actually caused it to eliminate it happening again.
Ben
'85 930 - Black on Black
'95 993 Turbo - Silver
Old 07-02-2012, 08:09 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #21 (permalink)
Garage Queen
PorscheGAL's Avatar
I agree. Since I am replacing all the bushings in the front, I have a pretty good view from the bottom. I am not finding any damage elsewhere. This is also the first time I have had it up on my new lift so I am not able to say when it happened. I couldn't say whether it was before I bought it (2009) or after.
Stephanie
'86 911 3.4L, SSI with M&K exhaust
'87 930 Andial IC, K27 7006, Tial WG, 964 Cams, 36mm intake, BLWUR, MSD6AL, .9 bar, RarlyL8 HDRs and muffler
'12 Boss 302 Mustang, '05 Lotus Elise and '13 Ford Focus ST.
Old 07-03-2012, 03:35 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #22 (permalink)
Smart quod bastardus
fredmeister's Avatar
Originally Posted by PorscheGAL View Post
Folks
I found a crack on the crossmember subframe where the torsion bar retaining cap rest. Obviously, it will need to be welded, but how? Does the subframe need to come off or can it be welded in place?
I don't know how this could happen. I'm in the middle of a suspension refresh and found this problem.
Side view
bottom view
There is another crack in the top picture in the web of the piece that concerns me more. Problem with a crack, especially in an aluminum part that is susceptible to fatigue failure, is that once it is cracked it fails quickly.
You have to realize that the load from the torsion bar is reacted at the steel insert in the upper corner of the crossmember so you dont want it cracking in that area.
If it were me, I would go with the replacement piece and avoid using the welded piece.
fred
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, B&B intercooler, Snow Perf water/meth injection, GSF headers, k27S turbo, 36mm ported intakes, Innovate auxbox/LM-1, MSD 6AL2-Programmable, Adjustable wastegate housing (0.8-1.1bar)
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 07-04-2012, 06:23 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #23 (permalink)
never
I would never trust a welded suspension part. Aluminum is a funny metal, especially when welding. Alot of heat is generated and the grain structure will be altered. I am sure many of these exist in the parts yards.
Good luck
Old 07-05-2012, 11:37 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #24 (permalink)
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Copyright 2011 Pelican Parts - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
