Tranny bushing removal
Had a look around and really not sure how I need to proceed with tranny mount bushing removal and replacement in my 86 930.
Are the old bushings pressed out?
My new Rebel Racing poly mounts are a two piece design.
thanks in advance
Rod
"This Year ferrari's Ass is Mine"
Old 06-30-2012, 11:48 AM
xbmwguy's Avatar
subscribed
Old 07-01-2012, 05:51 PM
Wevo has an exchange service for the mount. Unlike the 911s, the 930s don't use the same two-bolt mount as the engine mounts. Sorry I don't know if they just press out. I know the stock motor mounts do... I had one pull the rubber out when I was lifting the car with an engine hoist via the mounts.
Ken
1986 930, 1969 Mach1, 2003 540 Sport, 2016 R1200RS
Old 07-01-2012, 06:24 PM
clexton1's Avatar
Trans Mount
I replaced mine with the DIY Wevo kit, rairly easy if you can weld. Cut the rubber away on the top side with a sharp utility knife and you will be able to push the rest out of the bottom.
Paul
'76 Turbo Carrera
Old 07-01-2012, 08:16 PM
Thanks Guys, started carving away the rubber at the top.
Old 07-02-2012, 03:46 PM
Banned
I would imagine heating the housing with a propane torche would make the bushings fall right out . . .
Old 07-02-2012, 04:40 PM
That bushing is very similar to the origonal rubber bushings in the front strut top mount camber plates.
Make a razor knife cut deeper down toward the narrow part of the mount in the middle about half way around and then put a big screwdriver in the middle and pry sideways. It will pop right out downwards.
Quick and no mess with heat or fumes.
It's the same way to remove the front strut rubber top mount bushings to install rennline monoballs.
Old 07-02-2012, 06:06 PM
IMR-Merlin's Avatar
I looked for the "best" way to remove the rubber mounts on the suspension for my build. I chose to pre-heat my powder coat over to 400F and put the part in the over till the rubber bushing swelled up (it's obvious) and then it just pushed out with a regular screwdriver. No fumes, little mess, just wear good gloves.
Old 07-02-2012, 06:12 PM
Thanks gents, that heating in the oven is really slick, i was able to push the bushings out with a screw driver after 10min at 400F
thank you
Rod
Old 07-02-2012, 07:59 PM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
