LinkBack Thread Tools Rating: Thread Rating: 1 votes, 3.00 average.
Custom Fuel Lines
Hi Guys
I recently purchased a 88 Porsche 930 Targa. I have only had the car a week.
I have been detailing the exterior, interior, and have turned my attention to the engine bay. I was shock to discover the rubber fuel lines. The PO did a hack job on the fuel lines going to the fuel distributor. It looks like the line has a split in it.
Please see the attached picture.
I was wondering if anyone has custom built this fuel line, using AN fittings, tees,
and steel braided lines? Is so what size lines and fittings? Would a 6 AN line be the correct size? I have read that I would need a Metric Female to AN male connector. I would like to get this fixed correctly so that I don't have to worry about any fires.
Any help would be appreciated.
Thanks in advance.
Regards
John
Old 07-09-2012, 06:42 PM
I am also
I am having Johnny the Delorean parts guy in forney Texas do my line right now. He redid some of my fuel lines for my CIS system on my 74. Did a nice job.
Signature Phrase " CATCH ME IF YOU CAN"
1988 Porsche 930 "Squerly" Built by "Porsche Doc"
1974 Porsche 911 (2003 - 2012)
2000 Boxster S (2006 - 2008)
Old 07-09-2012, 07:10 PM
What was cost roughly if you don't mind me asking?
Old 07-09-2012, 07:27 PM
He got a metal braided fuel line made for me using the stock hardware for 20 bucks. I had him make a couple of CIS lines for me a couple of months ago for 30. So I have been happy.
Old 07-10-2012, 02:26 PM
BoxsterGT's Avatar
Porsche Crest
This is an example of what I custom make for the Carrera 3.2.......
If you give me the dimensions, etc I can make a hose assy for your 930 to your specifications. I use only the latest Multi-fuel hose from Germany with the correct Metric fittings. It is available in plain rubber, Braided Zinc and braided Stainless Steel.
Len at Autosportengineering dot com
Old 08-13-2012, 07:06 AM
Porsche 930 Fuel Lines
I had Len MFG a fuel line from my rear pump to the accumulator, did a great job, looked factory, great customer service.
Old 08-13-2012, 09:34 AM
That looks like the CIS fuel return line. It's returning fuel to the tank so there isn't alot of presure in it.
It would be a good idea to have new fuel injection line installed on it with crimped on connectors instead of hose clamps.
Stainless braided hose hides the surface condition of the rubber line underneath, thats why braided lines should have an expiration date stamped on a metal tag on them so you know when they're old and should be replaced or they will dryrot under the metal braiding and eventually leak.
You see the dated stainless steel expiration tags on aeroquip lines professionally installed on aircraft and some race cars.
Nowadays kevlar or other aramid fiber braided lines are often used because of good abrasion resitance and strength with lighter weight.
Originally Posted by jpilcher View Post
Hi Guys
Thanks in advance.
Regards
John
Old 08-14-2012, 07:14 AM
BoxsterGT's Avatar
Porsche Crest
This appears to be PN 930-110-304-03 and it apparently is available thru our host for $120. Anyone have a photo of this hose assy out on a workbench?
What I really need is a 930 here in the shop to identify the routing around the various obstacles and to get the orientation correct.
If this is hard to get from Porsche or our host then its one more I will build a fixture for and add to my inventory.
Len
Old 08-15-2012, 02:31 PM
Old 08-15-2012, 05:36 PM
IF the QUALITY is there, can't beat them for 20~30 bucks...
Old 08-16-2012, 04:11 AM
Len is one of the truly honorable men left. Great work, fair prices, always
willing to help, and a wealth on knowledge.
Cole
Cole - 80 930 "The Old Sled"
Mods: TurboKraft Custom IC, 934 Headers, GSX 61, Zork, Port Work, SC Cams, Air Mod Fuel Dist Relocated, Water Meth Injection, BL WUR, MSD 6530, Greddy EBC, Synapse Bov, Short 2nd & 3rd with 8:37 R&P, Wevo Shifter, Coupling, and Mounts, MTX-L SSI-4, Big Brakes, Rebel Coilovers, Bilstein Sports.
Old 08-16-2012, 07:28 PM
BoxsterGT's Avatar
Porsche Crest
We have a 88 930 that just came in, so I took some measurements of this hose assy and began a basic mock-up of what I will offer as a replacement. This is in plain rubber hose..............
It has a 120 deg fitting at the bottom of the accumulator, a Banjo fitting at the Fuel Dist and a Female fitting just off the Tee.
Will test fit this and post my results. I am pretty sure this will require a fixture so all the lengths & clocking of the fittings is correct.
Len
Old 08-17-2012, 11:18 AM
BoxsterGT's Avatar
Porsche Crest
Hi John,
Its been a while since we spoke. Did you get your fuel hose/line issue resolved?
Len
Old 02-02-2013, 04:05 AM
Hi Len
I'm about 3 weeks from dropping my motor. I would like to go with the stock setup as shown in permalink #12.
I also need to get a price on the supply and return lines from the gas tank.
Thanks for keeping in touch.
Regards
John
1988 Porsche 930 Targa - 3.4L Twin Plug Motor, DC 13 Cams, Supertec Head Studs, ARP Rod Bolts, Port and Polished Heads, Garretson Andial Intercooler, GSX 61 BB Stage 5Turbo, Tial F46 WG .8 Bar Spring, PowerHaus Headers, Rarly8 Dual Tip Muffler, MS3 Pro EFI conversion, 57lbs. Cobra Injectors, Center Force Stage 2 Clutch , Rebuilt 4 Speed with LSD.
Old 02-03-2013, 06:16 PM
Norm K's Avatar
Reviving an old thread in the hope that Len will see it. Len, I tried sending you a PM but your box is full. Looking for a quote on a set of hoses for an efi conversion I'm doing to my `80 930, utilizing a 3.2 intake.
If the Army and the Navy
Ever look on Heaven's scenes;
They will find the streets are guarded
By United States Marines.
Old 08-13-2014, 10:45 AM
Large Member
krasuskyp's Avatar
Norm-
Len is adamant in every post to never ever PM him (he prob keeps his inbox full for that reason?).
I've seen him post his email publically here, so I'll share it instead of PM:
len dot Cummings at Verizon dot net
as you've heard / read, Len is very much quite the helpful gent to work with
Paul... CT | '87 930 | '08 M3 6gang vert |
past:
| '07 S6 | '98 M3 vert | '01 M5 | '96 993 C2 cab | '05 S600 Sport - biturbo V12@Just Not Right 495rwhp / 612rwtq |
| '58 TR3A | '01 S8 | '95 S6 6gang | '88 M5 | '87 190E 2.3-16 |
Old 08-13-2014, 11:55 AM
Norm K's Avatar
Thanks, Paul, I'll shoot him an email.
nk
Old 08-13-2014, 12:52 PM
BoxsterGT's Avatar
Porsche Crest
Hi John,
I understand you are going to or have gone to EFI on your turbo. I wonder how its going?
Do you have a post on it we can read about?
Len
Old 10-31-2014, 04:32 PM
onboost's Avatar
Len,
I have lines from an SC boxed and ready to ship for a re-fit using braided zinc.
Sent you an email earlier in the week. Waiting on a reply from you with a "ship to" address.. .
Thx,
Paul
RGruppe #180
Old 11-01-2014, 05:00 AM
