I've gone native
87 930 clutch pedal spring
Mine broke, pelican says it's NLA, anybody have a lead on one?
pn 93042300500 Will an '86 turbo spring work? TIA c
'07 997.1tt Blk/blk 600hp, bad to the bone |
I had my 86 930 pedal cluster apart for new bushings and powder coat, this is an 86 spring if it looks like yours it most likely will work?
Hope this helps Rod ![]() ![]()
"This Year ferrari's Ass is Mine" |
I've gone native
Yes, looks like it, yours must have been a late 86 build as that is the 87 up spring.
would u like to part with it? gotta ask c Last edited by Tt surgeon; 07-09-2012 at 09:50 PM.. |
I've gone native
Put the 79-86 spring on, used the quarters trick. worked well.
I'll bite. What's the quarters trick?
Ken 1986 930, 1969 Mach1, 2003 540 Sport, 2016 R1200RS |
I've gone native
Stick quarters or washers in Btwn the coils to spread them out. You need about another 1/8" to pop it over the pegs, that makes it easier. Just pluck them out w a needle nosed pliers when done. I did a search here on the board and found that trick.
Clever!!!!!!!!!
Thanks for the hint. |
I've gone native
I wish I would have come up with it, I found it here searching old threads.
I repaired mine and it's been working fine for 2 years now.
Photo attached..
![]() I simply drilled and tapped the ferrule that is crimped to the spring. I think I needed a LH tap though. The turnbuckle still works. ![]()
Thank you, HFR_Racer '87 930, 3.3 liter, K27 hybrid, Kokeln IC, Andial, B&B, Borla, 17" Supercups. |
I've gone native
interesting, so you drilled and tapped as opposed to welding it back?
I'm gonna give that a try, like to be all original. You don't remember the tap size by chance do you? tia c
Thread Tools | |
Rate This Thread | |
