Heavy gas pedal
Hi all. I am currently having a problem with my accelerator pedal sticking. It almost caused a issue while cruising around town.
Could anyone think of a solution on why this is happening? |
You may need new bell crank bushings at trans and motor. There is also a cable guide bushing in the tunnel just forward of the shift coupler access. I had the same problem and replaced the bell crank bushings at the trans. Works great now.
Thanks, I will look into that.
Is this something I could do myself? |
I've gone native
ck out the actual control arm where it meets the back of the pedal itself. Remove the pedal and take a peak at the mechanism.
On my car I removed the springs at the T body many years ago , pedal is a lot lighter , much like a newer car, but I done this to my friends 930's some work great some with no springs and some I detach only one of the springs , there are two slings. Beware on some cars if you remove both sping the t body doesn't close completely , so you should check for that. Good luck
1986 944 turbo -first car 1997 993 Cab 6 speed-sold 1992 964 C2 turbo SOLD, 911GT ,CIS, 428 fwhp 450 trq, Carrillo rods, 964 cams, TT retainers,7.5 comp 1.1 bar boost 320 ml black fuel head 009 injectors, 044 pumps, 60-1 T4/T3 dual scroll turbo |
Thread Tools | |
Rate This Thread | |
