Damn o-ring!
I have the konklein intercooler...I just broke an O-Ring today on the uppipe.
I want to replace all the O-rings like this, or atleast have a spare just incase so I ordered what pelican had....did I get them all or is there another number?
The throttle body is the one I really could not pin-point and say "yes" that is the one I need...
here is what i ordered.
999-701-124-40-M17 $2.25 1 $2.25
O-ring, Throttle Body to Air Box, 911 Carrera (1984-89), Brand: Victor
Reinz
930-110-230-00-M100 $10.25 1 $10.25
Seal, Turbocharger Outlet to Pressure Pipe, 911 Turbo (1978-89)
930-110-379-00-M136 $10.50 1 $10.50
Seal, Pressure Pipe to Intercooler, 911 Turbo (1978-89) Brand: OEM
999-701-469-40-M260 $3.75 3 $11.25
O-Ring, Pressure Pipe to Intercooler Inlet, 911 Turbo (1978-89) Brand:
OEM
999-701-473-40-M213 $3.75 3 $11.25
O-Ring (Turbocharger Outlet to Pressure Pipe), 911 Carrera / Turbo
(1987-1989), Brand: D P H
Buy the way the black O-ring is what I got at NAPA....and its a little to small and thin...
Signature Phrase " CATCH ME IF YOU CAN"
1988 Porsche 930 "Squerly" Built by "Porsche Doc"
1974 Porsche 911 (2003 - 2012)
2000 Boxster S (2006 - 2008)
Old 07-14-2012, 06:34 PM
Banned
This is the o-ring that actually goes on the throttle body (it is slightly larger than the o-ring that goes between the intercooler and the recirculation valve body, but that one works on the throttle body as well - I know from experience):
Pelican Parts - Product Information: 999-701-477-40-M17
Do you lube the o-rings? I have used lithium grease for years without problem, but others use silicone grease and grease intended for use with brake system o-rings . . .
Old 07-14-2012, 06:51 PM
Thanks for the ...
Thanks for the part number...I just ordered 3...
And yes I do use the silicon grease on them.. I have been having to remove the intercooler on and off for tuning and idle adjustment...for some reason the adjustment screw is upside down on this throttle body...weird.
and in all of my efforts I cut the o-ring...
Chris
Old 07-14-2012, 07:09 PM
